Yes.
Kernel is in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=580
Build is here: http://crewrktablets.arctablet.com/?p=1913
The CM10.1 build is JB 4.2.2. It will run on the stock kernel.
2012/11/19
You can restore a backup from CWM, BUT(!) you need to restore your partition layout before you can do this.
Cause we change the partition layout in the installation process, you need to restore it before.
In my opinion the only way would be, have a install of the custom rom used before, then make a CWM backup on external sdcard. If you want to fall back from CM10.1, reinstall the old custom rom, make the format_nand and restore after first boot the backup. That was the way I tested new versions of our roms.
Is the stock firmware available meanwhile or is the tab rooted?
2013/06/13
The Tablo is rooted.
Stock firmware: I'm not sure. Upon request Odys provided me 4 (literarily: four(!)) different firmwares (your link in android-hilfe is broken). They ware unable to procure the original firmware, they say, due to server problems, very cryptical answer. I think I have the original firmware, too, unpacked alas, but I'm not sure, if it's really the original one. I believe that I downloaded it shortly after I bought the tablet.
If you mean if the stock firmweare is available as source code, the answer seems to be no. At least I do not know of a source .
My concerns when switching to CM is with the SIM/UMTS. Therefore I'm hesitating. Genio is without SIM.
Ok, I guess you have the original firmware on the tab?
Let's dump it first: http://forum.xda-developers.com/showpost.php?p=35298423&postcount=462&nocache=1&z=8362006105273504
We do not have a tab with 3G. So you have to find it out.
2013/06/13
Yes, I found out.
I' m ready to test your CM. Before starting I like to know:
1. I have CWM on my Tablo. Don't ask me how I managed. Arctools, I believe. I forgot, Alzheimer is looking round the corner.
2. I could backup the TABLO via CWM on my external SD.
3. Would this be safe, could I rely on this backup, in case CM does not work correctly, and restore my original TALBLO-JB?
4. What else should I do before starting? (I'm installed your CM to my LOOX and my Neo X8, so I'm quite experienced, no freshmen), but my TABLO is for production not just for fun as my LOOX and the NEO , so I want to to play it safe.
82 Guest(s)
Devices in use: Desktop (75), Phone (7)
