2013/10/25
Is possible to include kernel of Mediacom 101 s2 (rk3066 - teclast a11 clone) so I can test the rom?
Here's link to stock rom:
http://www.mediacomeurope.it/ZeusInc/PressRoom/Documents/101S2.zip
Kernel is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1043
Latest build is here: http://crewrktablets.arctablet.com/?wpfb_dl=1041
diabolik247Per aspera ad astra, we rock the Tablets !
2012/12/08
Kernel is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1043Latest build is here: http://crewrktablets.arctablet.com/?wpfb_dl=1041
Many thanks for your work.I have tested the rom on mediacom 101s2 all work fine except the brigtness there is no possibility to adjust it(sorry for my English i'm Italian)
ÂÂ
2013/01/13
hi oma, thanks for job about mediacom 101s2...
i would like to report any problems on this tablet using cm 10.1, specific kernel and nand_fix :
1) Brightness does not rule.
2) If you enable the multiuser freezes
3) during reboot by recovery the tablet remains stationary on the Home screen or bootanimation
can you help me, and another users like me, to risolve these problems or tell me about solutions??
thanks
What do you mean? Auto-brightness?
Other points sounds you have corrupted the system somehow. Do a fresh installation incl. eraseIDB.
2013/01/13
hi oma,
would yu like, if Is it possible, to upgrade your kernel of Mediacom 101 s2 using last kernel extract by backup tablet with last firmware that is at link: Â
http://www.mediafire.com/?6nqkcg2czggqk8n
for help to risolve any bug ?
thanks for grea job.
Yes, I can do that: http://crewrktablets.arctablet.com/?wpfb_dl=1173
Will the kernel resolve the brightness issue?
2013/11/07
I have a mediacom 875s2 (rk3066 board) I have the same issue, there is no way to control brightness, or change brightness level, and sometimes I see some glitches (white and black stripes) when screen rotates
 Internal SD card gets corrupted too, and there is no way to make it works
I tried some kernel but I have always the same bug
2013/11/20
Hi, and thanks for your work.
I think that this kernel should be for focaltech touchscreen http://crewrktablets.arctablet.com/?wpfb_dl=1173
Oma we need to use it for our 101s2 (2nd version with focaltech touchscreen) but when we replace it instead the base kernel.img we receive a blocking error, while when we use the first kernel version for the 101s2 the update goes ok but the touchscreen doesn't work.
The focaltech fullfile img is here http://www.mediacomeurope.it/ZeusInc/PressRoom/Documents/101s21304.rar
Oma, Could you help us?
Thanks a lot.
2012/11/19
it is nearly impossible to extract a single driver and his components from kernel.img and to transfer it to  another kernel.img.
What we need first is a dmesg and logcat from stock in conjunction of the stock rom.
Then we could look at the system.img and perhaps at the kernel.img and find something to make it work.Â
2013/11/20
JochenKauz said
it is nearly impossible to extract a single driver and his components from kernel.img and to transfer it to  another kernel.img.Â
Thanks for your reply. Maybe you can exctract the full kernel.img from the focaltech version rom and prepare itfor cm10 rom!
Thanks Again.
74 Guest(s)
Devices in use: Desktop (62), Phone (12)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
