2013/10/29
i have the Nextwolf 7 Dual Core Tablet, i installed your CM 10.1 Build with the Stock Kernel and the fixes from this site:Â http://crewrktablets.arctablet.com/?p=1913
Everything is working excellent, except the screen Orientation. My Screen does not auto rotate.
As a workaround i use a tool to manually change the the orientation of the screen, but it would be really nice if anyone have a real fix for this issue?
Here are 2 links to the same devices if this helps to fix the issue.
http://www.weisung.net/product/49.html
http://www.dns-shop.ru/catalog/i160177/7-planshetnyj-pk-dns-airtab-e77.html
Thank you in advance for your help.
Inno
Install this: http://crewrktablets.arctablet.com/?wpfb_dl=1045
Load Androsensor from Play-Store and post axis with highest value (example) for:
- tab vertical, landscape (y=+9.8)
- turn left to portrait (x=+9.8)
- turn right to portrait (x=-9.8)
- tab horizontal screen up (z=+9.8)
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=1056
Give the values with +/- , see post #7.
This looks better. We will continue tomorrow.
69 Guest(s)
Devices in use: Desktop (58), Phone (11)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
