2014/02/03
I'd like to compile the CM10.1 source tree for the Odys Noon tablet.
I've adapted this guide to rk30board: http://www.arctablet.com/blog/forum/arnova-g2-general-discussions/tuto-building-cyanogenmod-10-1-based-android-4-2-1-from-source-for-all-rk2918/
Kernel img. is copied to appropriate place.
This is working:
. build/envsetup.sh && breakfast rk30board
But I'm stuck on:
. build/envsetup.sh && brunch rk30board
Error message is:
make: *** Keine Regel, um »bacon« zu erstellen.
What am I doing wrong? Why can't I compile target "bacon"?
2012/11/19
we are on a out off cm area.
only make a . build/envsetup.sh
then lunch, choose rk30board and do a make.
Depending on the cores you have have... make -j4 (for 4 cores to use), or higher or lower.
2014/02/03
Thanks, it's compiling now... brunch was not working (rk30board not in the menu).
I put this in .repo/local_manifests/roomservice.xml
<?xml version="1.0" encoding="UTF-8"?>
   <manifest>
   <project path="device/rockchip/rk30board" name="crewrktablets/android_device_rockchip_rk30board" remote="github" revision="cm-10.1"/>
   </manifest>
then repo sync,
. build/envsetup.sh
lunch (choose cm_rk30board-userdebug)
make -j4
Now it compiles.
2012/11/19
You used orginal CM10.1 repo?
Then you will get problems, cause patches are needed to the framework.
If you want to reproduce our CM10.1 release, look at this:
https://github.com/crewrktablets/android_cm
and follow the readme.
63 Guest(s)
Devices in use: Desktop (55), Phone (8)
ondateste
lilila3
Anatrop
antoniors021
wemiy54158
sidor
