Casper CTA-E10-16A-3G Upgrade
2014/11/24 - 21:39
Yes, do NOT flash the loader.
Check with this parameter: http://crewrktablets.arctablet.com/?wpfb_dl=1432
EraseIDB wipes the partition layout and the parameter files defines the new one.
eaktuna
Forum Posts: 14
2014/11/24 - 22:01
I'm sorry for making you tired. But it's same again.
2014/11/24 - 22:07
We will find a solution. I shall prepare something for you in a few days. Flash back stock in the meantime.
eaktuna
Forum Posts: 14
2014/11/24 - 22:24
Thanks a lot. I am waiting your reply.
Best regards,
2014/11/30 - 11:12
Ok, here we go: http://crewrktablets.arctablet.com/?wpfb_dl=2277
Copy your kernel.img and the Omni system.img into folder rockdev/Images and try again.
eaktuna
Forum Posts: 14
2014/11/30 - 15:52
Thank you for your reply. But unfortunatly same thing happened. Tab boots to cwm and E:Can’t mount ect. apears.
2014/11/30 - 16:02
Download again: http://crewrktablets.arctablet.com/?wpfb_dl=2277
recovery.img is now stock and should format the user partitions.
eaktuna
Forum Posts: 14
2014/11/30 - 18:16
Now tab boots and casper logo apears and still.
2014/11/30 - 18:46
Does not boot into Omni?
eaktuna
Forum Posts: 14
2014/11/30 - 19:06
No it doesn't.
2014/11/30 - 19:08
Last idea, there is a parameter file in the pack named parameter_org. Load this file and flash again, incl. eraseIDB.
eaktuna
Forum Posts: 14
2014/11/30 - 20:33
ERROR: Download file failed
ERROR: Run failed
67 Guest(s)
Devices in use: Desktop (61), Phone (6)
DAK78
wheaten156
luislx
algua
Twotrains
alexanddercrb
