2013/11/02
I want to upgrade my Casper CTA-E10-16A-3G 10'' 3G tablet. It is android 4.1.1 . I want kitkat o 4.2.2 . I mostly want kitkat rom. Is this possible?Â
My device info is
Kernel version : 3.0.36+
Screen: 10,1"
CPU:Â Cortex A9 Rockchip RK3066
Ram:Â 1 GB
16 GB
WiFi, 3G
Camera 2 Mp
Is the stock firmware available?
Downloaded this twice now and always get CRC failed, file is corrupted.
Ok, kernel is in the archive now: http://crewrktablets.arctablet.com/?wpfb_dl=2264
Can you pls upload some logs, that I can see your hardware?
Boot tab fresh, open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
eaktunaPer aspera ad astra, we rock the Tablets !
Tab has RK903 wifi.
With your 3.0.36+ kernel you should be able to flash this build: http://crewrktablets.arctablet.com/?p=3555
Change the kernel in folder rockdev/Images. Flash according to instructions. Do not flash the loader. Step one of the instructions is not necessary. After first boot into CWM install the 160dpi fix and this one: http://crewrktablets.arctablet.com/?wpfb_dl=2169
2013/11/02
I tried to flash rom. I install 160dpi fix and overlay fix. I reboot system. Tab boots and casper logo apears for 10 sec. Then tab boots again automaticly to CWM.
E:Can't mount /cache/recovery/command
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
These apear to end of the screen
What will I do? do I have a mistake?
Could be that we need stock recovery first to format the NAND properly. Load this http://crewrktablets.arctablet.com/?wpfb_dl=910 into the RKAndroidTool and try again incl. eraseIDB. The recovery will format your NAND and tab will boot into Android. Start tab into flashmodus and flash the CWM (recovery from the pack). Untick kernel, boot, system. In CWM just install the two fixes.
No, something with the partition layout. Use this parameter (unzip and replace in folder rockdev) und flash again, incl. eraseIDB.
Sorry, link is missing: http://crewrktablets.arctablet.com/?wpfb_dl=2043
Currently Online: runehansen76
74 Guest(s)
Devices in use: Desktop (61), Phone (13), Tablet (1)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
