2015/12/21
Hi there,
after 3 Years with no Updates I started to google around to find an alternative ROM for my CaptivaPad 10.1 Quad FHD
It's a Rockchip 3066 Device running Alex Kernel 3.0.36+ #337 so I found an interesting thread in XDA-Forum.
After a lot of reading and hesitating I did flash the RK31 ROM form OMA V1.3.2 (and a lot of other versions up to CM12.1) This one is booting with my backup of the boot.img
Now my 2 Problems I can not enter Recovery. I tried flashing CWM and the stock Recovery from your archive. But the tablet boot only to system or to bootloader. The CaptivaPad has only 2 hardware Buttons (Power and ESC) if I press both then Bootloader is started only ESC does nothing. Resulting to that I can not flash the nand format fix.
The second problem which was solved for another Captiva Tablet (I read in the XDA Thread) is that Wifi does not work. I hope that there is a chance to get this working. Sadly i only backuped the boot.img from the stock rom. I know my fault.
I already tried to split the boot.img with AndroidImageKitchen to get the kernel.img only. I thougt this could be the problem why i can not enter recovery but no effect. Pad still boots to system or bootloader.
Perhaps someone could help me out.
Thanks an merry Christmas.
Is the stock firmware available?
Pls upload the boot.img.
This looks more like a RK3188 (CaptivaPad 10.1 Quad). Are you sure it is a RK3066 (dual core)?
Ok, here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2767
Kernel is very old (10 Oct 2013), so it is a JB kernel.
Check with this build: http://crewrktablets.arctablet.com/?p=5617
Just change the kernel in folder rockdev/Image before flash.
There is no NAND fix. In CWM just do a factory reset (see instructions.txt).
Super. Danke für das Feedback und das Bier!
59 Guest(s)
Devices in use: Desktop (56), Phone (3)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
