Brightness FIX
Simple hack for fixing brightness on some RK30 devices
uncoder
2013/11/25 - 09:14
Oma,
Yes, it work when I use both fixes (your boot.img and patched lib). But we (875S2 owner) have one problem. Any your pathc won't work for me.
I don't know why, but in this tablet to system partition mounted /dev/block/mtdblock8 device.
I try to change this path in your patches but have not success.
Now i using this method: mount your system.img to my computers filesystem, copy some files from your patches to mounted system image, and then flash device with this system.img. :)
uncoder
2013/11/25 - 13:36
This is my images set for now:
ONLY FOR Mediacom 875S2 / GoClever R83.2 !!!
kernel.img - Stock device kernel
boot.img - Boot image modified by Oma for patched brightness lib
system.imgcrewrktablets 1.3.3 system image with patched brightness library, and TabledUI fix included.
Download link: https://mega.co.nz/#!blpinYSA!HN_KzT_7EMJ5evaaR0OuLmhcdS8L-v5BOy0XxAWF6Uw
It necessarily to apply NAND fix patch!!
My next purpose: fix short graphics bug when device switch screen orientation
2013/11/25 - 18:50
mounts.pngImage EnlargerHm, system on mtd8 is normal.
uncoder
2013/11/25 - 20:21
Hmm.. I have same mount points.
Oma, when I scrolling web page or apps in market, I have graphical lags. It's look like wrong scanning on TV screen.
And when I rotate screen in logcat appears this error:
E/SurfaceFlinger( 88): GL error 0x0506
I/InputReader( 5929): Reconfiguring input devices. changes=0x00000004
I/InputReader( 5929): Device reconfigured: id=1, name='focaltech_ts', size 1024x768, orientation 3, mode 1, display id 0
I/ActivityManager( 5929): Config changes=480 {1.0 ?mcc?mnc en_US ldltr sw721dp w768dp h976dp 160dpi xlrg port finger -keyb/v/h -nav/h s.48 themeResource=null}
E/ImageWallpaperGL( 6069): requested texture size 1451x1024 exceeds the support maximum of 0x0
D/dalvikvm(25055): GC_EXPLICIT freed 322K, 48% free 3987K/7588K, paused 2ms+6ms, total 45ms
W/HostnamePreference(25055): setting empty hostname
D/BluetoothAdapter(25055): 1096102992: getState() : mService = null. Returning STATE_OFF
D/VoldCmdListener( 85): cryptfs cryptocomplete
E/Cryptfs ( 85): not running with encryption, aborting
D/dalvikvm(25055): GC_CONCURRENT freed 193K, 44% free 4283K/7588K, paused 1ms+3ms, total 28ms
I/dalvikvm(25055): Jit: resizing JitTable from 4096 to 8192
May be you know whats wrong with graphical subsystem? (Mali 400)
80 Guest(s)
Devices in use: Desktop (63), Phone (17)
heftpflaster
rk.13
