BRIGHTNESS FIX MEDIACOM 101S2 + JB BY OMA 2.5
NO CM10
xmaxxmax
2013/12/02 - 14:24
Hi, thanks Oma.
I've tried both aosp (slow) and cm10.1 (better but with autorotation problem and random freeze) but i was not fully satisfied so i downloaded http://crewrktablets.arctablet.com/?wpfb_dl=666 (jb 4.1.1 2.5 oma version) and i've found best system for my pad (very fast and smooth).
The only problem i've found is about the brightness settings (unable to swap beetwen brightness levels) so i've tried the solution for cm10.1 without success (with cm10 it solved my problem).
Have you got a solution for this problem?
Thanks. Thanks... and Thanks Again ;-)
77 Guest(s)
Devices in use: Desktop (70), Phone (7)
hans41
rickybk
soniya07
ironmangitar
