2012/09/27
Hi.. i have a Cube U30gt-h with the CM10.1 v1.3.2 rom intalled..All run perfect but one thing not function properly. I have an stereo bluetooth headset that pair ok with the tablet, but the sound still output through the internal speaker.
I need to change something to have audio throught the BT Headset.
Thanks for all.
Unfortunately I don't have the hardware. So, please test: http://crewrktablets.arctablet.com/?wpfb_dl=997
2012/09/27
Thanks for your quickly answer Oma, I flashed the zip with CWM and reboot, connect the Headset and nothing happens, still the ouput through the internal speaker.
I notice that when i push the Vol+ or Vol- with the headset connected the icon that appears with the volume bar is a Speaker and before with the others ROMS the icon was the Bluetooth mark.
Another thing that i notice is the USB Connection. Nothing happens when i plug the USB cable to my PC, don't appears the Screen with the Activate USB Mass Storage....this will be for the partition type of the internal Flash (Ext4 file format)????
Thanks for your help sincerely.....
Sorry about that! I have no other idea where we "lost" that ...
... in v1.3 it works. So, you may use that build.
I am not sure if it woks, but try to update latest gapps: http://wiki.cyanogenmod.org/w/Gapps
Otherwise do not update Chrome and you will be fine.
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=997
admin, giulia.spiderPer aspera ad astra, we rock the Tablets !
83 Guest(s)
Devices in use: Desktop (73), Phone (9), Tablet (1)
Ellocojoe
Tonysc17
olegator
Ur
beelink
TheMentor
