AOSP 4.2.2 V3.4 boot problem
obajtektsw92
2014/09/02 - 18:01
I have problem with this version.When i change my kernel and recovery the tablet stays on bootlogo(not boot animation). Iv try to change boot.img from stock fw but it doesnt change anything. Always try to format NAND then the tablet restarts when the boot anim wants to show. Previous versions work ok but this not. Pls help me with this problem. Thanx with advance
2014/09/06 - 20:12
Which tab is it? Try to flash with generic stock recovery first: http://crewrktablets.arctablet.com/?wpfb_dl=1036
obajtektsw92
2014/09/06 - 20:46
Prestigio PMP5870C. Recovery doesnt repair it at all. Problem is in Mali/gralloc modules. If i change it to my stock rom modules the rom boots but the performance is poor. Its starting when i flash zip from attachment. Its not your fix. Iv modified this with stock libs and modules.
obajtektsw92
2014/10/08 - 23:48
Any clue what cause the problem ?
obajtektsw92
2014/11/10 - 02:46
 Ok. Iv managed to boot AOSP 4.2.2 but wifi dont work and internal and external memory dont work. These are the only bugs that i have at the moment. Any help ?
Currently Online: vishu bhatnagar
53 Guest(s)
Devices in use: Desktop (52), Phone (2)
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
