advice for best rom with bigger data partition for RK3066 Quad core Proline L10A1G tablet
need custom rom / fix to increase data partition from 1 GB in order to load more apps
enerdude
2016/04/17 - 17:53
Hi I have this tablet:
http://www.takealot.com/proline-10-l10a1g-android-tablet-black-3g/PLID30664149
It has 16GB flash storage anbd 1GB RAM but seems data partition is only 1GB which limits app installation.
Where can I get the best custom ROM / fix to increase the 1GB data partition to something bigger?
Specs when running CPU-Z on this tablet:
--- SOC ---
Cores : 4
Architecture : 4x ARM Cortex-A9 @ 1.6 Ghz
Revision: r3p0
GPU: Mali-400 MP
--- Device ---
Model : L10A1B-R (ACTIVE_L10A1G)
Brand: ACTIVE_L10A1G
Board : rk30sdk
Hardware : rk30board
-- System --
Android version : 4.2.2
Bootloader : unknown
Build ID : ACTIVE_L10A1G-eng 4.2.2 JDQ39 test-keys_OTA:MID_v1.0.0_20131114.163633
Kernel Architecture : armv7l
Kernel Version : 3.0.36+ (eng.zhangxianglong.20131114.163700)
2016/04/18 - 20:07
Is the stock firmware available?
enerdude
enerdude
2016/04/18 - 20:18
Not sure.  But maybe you can explain steps to me how to use CWM or some recovery in order to dump it for you?
Thanks in advance
2016/04/18 - 20:33
I guess this is a RK3188 architecture. Can you pls verify with this app: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
enerdude
enerdude
2016/04/18 - 20:55
Yes
I attach screenshot:
View post on imgur.com
2016/04/18 - 21:03
enerdude
enerdude
2016/04/18 - 22:34
Ok have come across some problem.
I am running win7 64bit but also tried it on another pc win7 32bit.
Your batch file to ROOT / dump the firmware does not seem to work.  I have some very limited experience with adb when I used it with my samsung galaxy s3 in the past.
After running driverinstall for rockchip driver my tablet respond with "usb debugging enabled" and mount 2 empty drive letters on my pc.  But when I run "adb devices" from cmd prompt it shows no device. I assume this is the problem why your batch file cannot communicate with my tablet?
Also, as you know, my tablet give option to be mounted as usb storage which allow me to see 2 populated drive letters in my pc.  But this mode is not used when using adb, right?
Maybe I need another adb / rockchip driver here: ?
http://www.rockchip.nl/downloads/
How would I know adb works correctly?  Should it show my tablet in list when running "adb devices" ?
Thanks for your help in advance
2016/04/19 - 19:43
Is the device rooted?
enerdude
2016/04/19 - 23:57
Yes.  Already checked it with root checker app on playstore.
2016/04/20 - 18:40
Ok, then open a terminal on the tab and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd > /mnt/sdcard/mtd.txt
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
enerdude
2016/04/23 - 23:57
Hi Oma
Sorry for late reply, I was a bit sick with the flu.
I have dumped all the files using your terminal commands above and zipped them up:
http://www.datafilehost.com/d/99ea0af7
(On the download page, first untick "Download with Secured Download manager" otherwise it tries downloading with their crappy download manager)
P.S. I also included df.txt inside zip file.  Here is the output:
Filesystem             Size   Used   Free   Blksize
/dev                  448.1M  68.0K  448.1M   4096
/mnt/secure           448.1M  0.0 K  448.1M   4096
/mnt/asec             448.1M  0.0 K  448.1M   4096
/mnt/obb              448.1M  0.0 K  448.1M   4096
/system               511.5M  407.0M  104.5M   1024
/data                 1007.9M  876.0M  131.9M   4096
/cache                372.0M  16.2M  355.8M   4096
/mnt/sdcard           12.9G  738.6M  12.2G   8192
/mnt/external_sd      3.7 G  8.0 K  3.7 G   4096
/mnt/asec/jackpal.androidterm-1  2.0 M  628.0K  1.4 M   4096
/mnt/asec/com.facebook.katana-1  36.0M  34.7M  1.3 M   4096
/mnt/asec/com.facebook.orca-1  30.0M  28.8M  1.2 M   4096
/mnt/asec/com.speedsoftware.rootexplorer-1  4.0 M  2.4 M  1.6 M   4096
/mnt/asec/com.joeykrim.rootcheck-1  7.0 M  5.9 M  1.1 M   4096
/mnt/asec/com.ghisler.android.TotalCommander-1  3.0 M  2.0 M  992.0K   4096
/mnt/asec/com.a0soft.gphone.app2sd-1  6.0 M  4.6 M  1.4 M   4096
/mnt/asec/org.mozilla.firefox-1  41.0M  39.9M  1.1 M   4096[/code]
My real problem is the /data partition that is only 1007.9M which limit app installation space!
Thanks for your help so far!
2016/04/24 - 16:33
The dmesg log is not perfect. Pls reboot the tab and do it again.
PD got several virus warnings with this filehoster
enerdude
2016/04/24 - 22:45
I use this filehoster a lot without problem. To avoid virus warnings just untick the option below download button before clicking link to avoid popup.
New dmesg log:
https://www.datafilehost.com/d/d7fdfc08
2016/04/25 - 17:11
Wow, MT6620 wifi. This is far away from any standard for a RK30board. I cannot support that. Sorry.
enerdude
2016/04/26 - 00:15
Sorry to hear.  Think I'm gonna return this crappy tablet to the supplier.
So I assume there is no tool to keep same firmware but just increase /data partition?
Thanks for your help anyways
84 Guest(s)
Devices in use: Desktop (60), Phone (24)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
