2015/06/01
Hi,Â
I have an RK3066 tablet and tried to find an appropriate upgrade ROM in vain.
I'm looking to upgrade at least to 4.2 and have a clean and slim version. Ideally with a bigger partition for apps. Currently only 1 GB of a total of 8GB.
Attached you have the DMESG log and a screenshot with the original firmware details.
Please let me know if there is already a ROM that would be a good fit for my configuration or you can help me with a custom build.
Thank you.
With the 3.0.8+ kernel this is the latest possible build: http://crewrktablets.arctablet.com/?p=1913
Dump your firmware first. We need the kernel.
2016/04/21
Hi Oma7144,
The dump is uploaded to below. Please help. Thanks.Â
https://drive.google.com/file/d/0B79Zq4ozxYIuRmpQRUVDejlNWGM/view?usp=sharingÂ
Thomas
Tab has RK903 wifi.
[Â Â Â 5.169224] Current WiFi chip is RK903.
[Â Â Â 5.924607] FW_PATH = /system/etc/firmware/fw_RK903.bin
[Â Â Â 5.924610] NVRAM_PATH = /system/etc/firmware/nvram_RK903_26M.cal
[Â Â Â 5.975317] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
Just for right naming, what is the correct name and brand?
Pls check also system.img, it has only half of the typical size.
2016/04/21
Hi Oma7144,
Thank you for getting back.
My tablet is called "ARENA Scientific Tab-X 9.7 Retina-IPS 32GB"
Dual core 1g ram.
For the system.img, I tried twice by using your simple tools. It is around 512 mb in the sd card after dumping. But when I put the cars to PC and tried to copy, it said sd card has issues and require a scandisk to repair. And after repaired, the file size became 2xx mb. Do you need a full size system.img?Â
If yes, maybe I need to dump it by using another way...
Thanks.
Thomas
Sounds you corrupted the sdcard by unsafe put off. Pls use settings/storage to unmount the sdcard first.
2016/04/21
Hi Oma7144,
The system.img is dump successfully . Pls download it again. Pls let me know if my tablet can flash the CM10.1. Thank you.Â
https://drive.google.com/file/d/0B79Zq4ozxYIuSndtTjRoMDFJVnc/view?usp=sharing
Thomas
Dump looks ok.
Kernel is in the archive now: http://crewrktablets.arctablet.com/?wpfb_dl=2867
You can try the CM10.1 build.
2016/06/24
Hi
I try to upgrade a Horizon h101d1hd rk3066 tablet withÂ
Odys Genio cRom v1.4. with no luck. Now the tablet not open at all.
Any advice? Anyone with the original kernal and rom?
69 Guest(s)
Devices in use: Desktop (59), Phone (9), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
