Wifi issue with unknow RK3026 tablet
If I try to turn wifi bar on it will automatic slide to off position. It says that "turning wifi on" but nothing happens.
Vohukain
Forum Posts: 17
2014/08/25 - 17:14
2014/08/25 - 17:47
Did you flash also the loader?
Vohukain
Vohukain
Forum Posts: 17
2014/08/25 - 18:08
Yes I did.
Do you have any ideas how this could be fixed?
Vohukain
Forum Posts: 17
2014/08/25 - 20:20
I found out that my tablet could be similar with pulwin p6200d. I hope that helps little bit. Here (post #187) are some pics of pulwin. It looks just like my tab (inside and outside). Pulwin has bigger memory (16gb).
EDIT: I contacted the Pulwin supplier. I hope they can send to me stock firmware. I will be updating here if I get that firmware.
Vohukain
Forum Posts: 17
2014/08/26 - 08:43
Here are some pics from inside. Hope that helps. https://www.dropbox.com/sh/pmodv70x0uvurxl/AAALfSP5PdsmcaxXsaIKattsa?dl=0
Vohukain
Forum Posts: 17
2014/12/12 - 12:53
SOLVED! Thanks to Oma!
Oma found out that my wifi is actually Atheros AR9271 so all I need to do was flash Oma Cube U25GT2-H JB v1.0 rom with my genuine kernel. Everything is working now!
Check also this thead
88 Guest(s)
Devices in use: Desktop (79), Phone (9)
swan12
heftpflaster
