2013/12/29
I have picked up a cheap Archos 70b Cobalt and wanted to install one of the custom roms from here. I do not see the specific device in the kernels or listed in roms. It has a 3.0.36+ kernel, so I hope it will work with later custom roms.
Device spec here:
http://archos.com/gb/products/tablets/cobalt/archos_70bcobalt/specs.html
ROM image here:
http://files.archos.com/recovery/fw/elements/archos_70bcobalt/update.img
Any help would be appreciated.
Best Regards,
Wayne
Let me have a dmesg log.
Try to attach the log again.
I need a log from 0.0000000 sec. Reboot the tab and do the log again.
<4>[ 47.754340] Current WiFi chip is RTL8188EU.
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2744
Just change kernel in folder rockdev/Image before flash.
Negative. No kernel for 4.4 or 5.x available.
65 Guest(s)
Devices in use: Desktop (59), Phone (6)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
