Root and Dump the stock firmware ...
... or do NOT flash anything into your tablet without having a fallback!
2015/01/24 - 15:24
Simple tool to Root and Dump the stock firmware via PC.
If you'd like you can upload the files and post a link here. I will check if anything is ok.
RD_01-1.pngImage Enlarger
RD_02-1.pngImage Enlarger
Vohukain
left_gangster
Forum Posts: 13
2015/03/09 - 01:19
I need the stock firmware for Irulu X10 (or ExPro X1) and the cpu is RK3028A Cortex-A9. If someone has it please share it.
Lannig
Paris, France
2015/03/12 - 14:17
Nice and useful tool, but will work only if the firmware is pre-rooted (gives a root shell right away over "adb shell") won't it?
On other (non pre-rooted) tablets, the "adb remount" will just give "remount failed: Permission denied"
On such tablets, firmware can be dumped using RKAndroidTool (version >= 2.1, I think) under Windows or rkflashtool under Linux (which I normally use).
2015/03/12 - 19:20
One will not get a privileged shell when
ro.secure=1
We see that not often on rkboards.
Willem
2016/08/30 - 11:50
Hi Oma,
I tried to follow the steps but it doesn't seem to work like it should (see screendump) does it have to do with the password that is needed (and I don't have) to logon to the tab?
thnks,
Willem
2016/08/30 - 17:20
Screendump?
Is USB debugging on? RK Driver installed properly? Which Windows?
Willem
2016/08/31 - 11:41
Screendump?
Hi Oma,
I can't get ĂŻn"the tab to put USB debugging on because I don't have a password?
RK driver is installed and I use Windows 10.2016-08-31-11.31.01.jpgImage EnlargerUntitled.jpgImage Enlarger
thanks Willem
2016/08/31 - 18:31
Pls enable USB debudding in developer options.
JEssicannn
Forum Posts: 252
2019/10/23 - 02:04
44 Guest(s)
Devices in use: Desktop (34), Phone (10)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
