Lost password?
The forums are currently locked and only available for read only access
[ ROM wanted ] ODYS BRAVIO
This topic is locked
Forum Posts: 6314
2014/05/02 - 17:23
Fine.
Forum Posts: 6314
2014/05/04 - 17:35
Are you running the 2.01 build?
I did a build based on that. Mounting of that build is not very clever. So I'd like to see a screenshot of settings/storage.
Furthermore can you pls upload some logs? Open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd > /mnt/sdcard/mtd.txt
Thank you in advance!
Bravio_01.pngImage EnlargerBravio_02.pngImage Enlarger
freibergisch
Germany
Forum Posts: 16
2014/05/05 - 09:01
I will post some screenies later with the cat's and dmesg. And yes I flashed thhe unofficial 2.0.1 and the mounts are better then mounts from earlier build 1.0.x. because the internal storage was cutted into sd memory and nearly 1gb system memory. Now with new build the system memory and sd are the same. System takes memory from internal storage now without extra limited partition.. But now app2sd is absent... this you do not need anymore because of the 6gb useable memory now.. complicated to describe all things :)
So, i'll return back if I have your desired images and texts.
Cheers
Marcus
Odys Bravio - 7.85" Tablet - 4.2.2 Stock - Rooted, xPosed
Odys Connect - 7" Phablet - 4.2.2 Stock - Rooted, xPosed
freibergisch
Germany
Forum Posts: 16
2014/05/05 - 13:04
So, here are the files..
in rar file there are cmdline, mtd and dmesq after reboot..
TWRP for bravio 1.0.1 does not work anymore, so I love to see cwm on it..
Odys sent me a list with current update.img's for many devices.. So I can provide you with current builds from the latest devices :)
82 Guest(s)
Devices in use: Desktop (79), Phone (3)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
