as I mentioned in the cube thread, I want a kitkat rom for my Odys Bravio tablet.
DMESG comes also in some minutes..
So if you need some other files, just ask me
Best regards
Marcus
Download 4.2.2 ROM:Â Dropbox-Link
Download DMESG:Â Dropbox-Link
Odys Bravio - 7.85" Tablet - 4.2.2 Stock - Rooted, xPosed
Odys Connect - 7" Phablet - 4.2.2 Stock - Rooted, xPosed
Ok, very new build:
RK3026_ANDROID4.2.2_ODYS_BRAVIO_V2.0.1_20140311
Kernel huang #21 preemt 01.03.2013: http://crewrktablets.arctablet.com/?wpfb_dl=1725
There is a older kernel chen #117 preemt 25.12.2013 in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1714
The dmesg is crap. Pls boot tab fresh and try again a dmesg.
Yes this is a not official build, should delete it from dropbox. But maybe you can use it for making kitkat roms?
I also make a new dmesg now..
DMESGÂ after reboot
Thank you for replying.
Best Regards
Marcus
Ok, very untypical hardware:
- Goodix GSLX680 touchcontroller
- Realtek RTL8723AU wifi
I am not sure on the huang #21 kernel if it has selinux on. Pls flash this build into the tab (change the kernel in folder rockdev/Images). Just to see if the kernel is booting the build.
which kernel shall I flash instead of the kernel inside the download link?
Because my tablet only has 4.2.2 kernel.. Not 4.4.2.
Or do you have a working 4.4.2 kernel for rk3026 devices that fits into my tablet specs?
We could also discuss in German..
Marcus
Thats what I'd like to find out, if the kernel huang #21 (post #2) will boot the KitKat build.
i will test it later this day, my tab is atm not available.
So I have to choose the odys bravio 2 kernel from your second post and the rest of the build.
We will see if it works.. I hope it does not kill my tab But I think I can find a way to unbrick it (flashing original fw).
Thank you
Marcus
I flashed the rom but it did not boot. I only saw the android 4.2.2 screen and then it stopped working..
So I flashed the update.img back and now I have only 2GB internal memory.. How to fix that?
The partition table seems to be corrupted.
EDIT: workes now.. used the update.img partition file..
Ok, very untypical hardware:- Goodix GSLX680 touchcontroller
Hi OMA how do you get this useful information?
Tablet Master-G G-820c (Yifang M900HC) 8" - RK2918
Tablet Onn 07HD (Yifang M7000NBD) 7"- AML8726-MXS
Tablet Onn 07DX (Yifang M7000KD) 7" - RK3066
Tablet Onn 07D (Yifang M7100KLD) 7"- RK3026
Phablet Samsung Galaxy Note 3
Cellphone Samsung Galaxy Trend
I just read the dmesg log.
Btw: found your tabs kernel, which is here: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-roverpad-trc7-android-4-2-2-jelly-bean-custom-root-firmware-20140421/#p41653 ... if you'd like to upload your log or play around with the build
Ok, no selinux-kernel. Do Odys provide the kernel source code?
67 Guest(s)
Devices in use: Desktop (58), Phone (8), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
