Gents,
KitKat has landed on Vido N70S (FZ/GZ with RTL8188 wifi)
selinux kernel FZ feng #141Â preempt 06.06.2014
selinux kernel GZ feng #189Â preempt 04.07.2014
– system ext4
– selinux kernel feng #64 preempt 15.05.2014
– internal storage 2,0 GB
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
- to improve UI feeling disable all animation scales in developer options
– load kernel modules > enable init.d ON in Pimp my Rom (reboot)
– to disable su notifications change notification in su app
This is a gen2 loader firmware.
– Oma -
aydin.gsm1Per aspera ad astra, we rock the Tablets !
Oma,
SELinux kernel you use in this rom is the same of the other two Kitkat roms you have released?
How can I get a SELiunx kernel for my Onn07DR/RK3026 or Onn07DX/RK3066?
BTW... thanks for your new release!
Tablet Master-G G-820c (Yifang M900HC) 8" - RK2918
Tablet Onn 07HD (Yifang M7000NBD) 7"- AML8726-MXS
Tablet Onn 07DX (Yifang M7000KD) 7" - RK3066
Tablet Onn 07D (Yifang M7100KLD) 7"- RK3026
Phablet Samsung Galaxy Note 3
Cellphone Samsung Galaxy Trend
Kernel are always tab specific.
If you can provide the yifang kernel sources we should be able to compile the kernel with selinux on.
Kernel are always tab specific.If you can provide the yifang kernel sources we should be able to compile the kernel with selinux on.
I'll try to obtain sources searching for it. Yifang/Nextbook/eFun is not known as providers of their software stuff,Â
Kernel for RK3026 Onn07DR is the one you posted in http://crewrktablets.arctablet.com/?wpfb_dl=1728 ,Â
or enclosed the file kernel.txt (its just "kernel" remove extension .txt) which is the one I extracted from boot.
BTW. In what state is this file taken from boot.img file? it differs a little from kernel.img
Update post #1 with latest kernel.
For testing pls find below the following kernel (change in folder rockdev/Images before flashing):
Vido T10 DZ - http://crewrktablets.arctablet.com/?wpfb_dl=2209
Incar 86v 1024x600 - http://crewrktablets.arctablet.com/?wpfb_dl=2280
Incar 86v 800x480 - http://crewrktablets.arctablet.com/?wpfb_dl=2283
Intracon FX2 Pad7 non BT - http://crewrktablets.arctablet.com/?wpfb_dl=2341
Manta MID704DC - http://crewrktablets.arctablet.com/?wpfb_dl=2373
Energy Sistem Neo 7 - http://crewrktablets.arctablet.com/?wpfb_dl=2414
PCB T700A (also Travel Rock T200) - http://crewrktablets.arctablet.com/?wpfb_dl=2424
Manta MID705DC - http://crewrktablets.arctablet.com/?wpfb_dl=2425
>>> Tabs with RTL8723 wifi (and BT) see
>>> Tabs with Atheros AR9271 wifi see
>>> Tabs with NMC1000 wifi see
>>> Tabs with ESP8089 wifi see
Before flash anything into the tab pls make sure you have the genuine firmware as a fall-back position.
You can try, but I guess it will not work.
Complete not working?
Every tab has its specific kernel (hardware abstraction layer). Without the genuine kernel you have no chance.
My recommendation: forget it and enjoy life!
2014/12/23
I was backed up partitions with this commands before flash it:
cat /proc/mtd
dev: size erasesize name
mtd0: 00400000 00004000 "misc"
mtd1: 00800000 00004000 "kernel"
mtd2: 01000000 00004000 "boot"
mtd3: 02000000 00004000 "recovery"
mtd4: 04000000 00004000 "backup"
mtd5: 08000000 00004000 "cache"
mtd6: 40000000 00004000 "userdata"
mtd7: 00400000 00004000 "kpanic"
mtd8: 4b000000 00004000 "system"
mtd9: 144000000 00004000 "user"
dd if=/dev/mtd/mtd0 of=/sdcard/misc.img bs=4096
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd4 of=/sdcard/backup.img bs=4096
dd if=/dev/mtd/mtd5 of=/sdcard/cache.img bs=4096
dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
1|root@android:/ # dd if=/dev/mtd/mtd0 of=/sdcard/misc.img bs=4096.
1024+0 records in
1024+0 records out
4194304 bytes transferred in 0.096 secs (43690666 bytes/sec)
1|root@android:/ # dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
2048+0 records in
2048+0 records out
8388608 bytes transferred in 0.185 secs (45343827 bytes/sec)
root@android:/ # dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
4096+0 records in
4096+0 records out
16777216 bytes transferred in 3.178 secs (5279174 bytes/sec)
root@android:/ # dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
8192+0 records in
8192+0 records out
33554432 bytes transferred in 7.407 secs (4530097 bytes/sec)
root@android:/ # dd if=/dev/mtd/mtd4 of=/sdcard/backup.img bs=4096
16384+0 records in
16384+0 records out
67108864 bytes transferred in 12.821 secs (5234292 bytes/sec)
root@android:/ # dd if=/dev/mtd/mtd5 of=/sdcard/cache.img bs=4096
32768+0 records in
32768+0 records out
134217728 bytes transferred in 25.462 secs (5271295 bytes/sec)
root@android:/ # dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
307200+0 records in
307200+0 records out
1258291200 bytes transferred in 316.916 secs (3970424 bytes/sec)
Ok, this is the stock firmware?
Zip boot, kernel, reocvery and system and upload it.
61 Guest(s)
Devices in use: Desktop (54), Phone (7)
