[ ROM ] Sumvision Cyclone Odyssey 7 Android 4.4.2 KitKat custom root firmware (2014/06/22)
Thanks Received: 1383
2014/06/22 - 23:48
Gents,
this is a KitKat build for Sumvision Cyclone Odyssey 7. Build is for RTL8188 wifi ;-)
Oma Cyclone KitKat build v1.0
– system ext4
– selinux kernel
– unified internal storage
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
- to improve UI feeling disable all animation scales in developer options
– to disable su notifications change notification in su app
 – Oma -
v1.0_1.pngImage Enlargerv1.0_2.pngImage Enlargerv1.0_3.pngImage Enlargerv1.0_4.pngImage EnlargeranschlĂĽsse.pngImage Enlarger
2014/08/24 - 12:14
No feedback here? Can sombody post a dmesg log?
onder7973
2014/09/03 - 12:50
Hi, I'm developing a custom ROM for this device. I used your ROM and modified few bits in the system.img (using xubuntu, logged as root). I tried to remove NovaLauncher, here's my shell script:
mount -t ext4 -o loop system.img android_sys/
# remove nova launcher
ORIGTS=`stat -c "%Y" android_sys/app`
rm android_sys/app/NovaLauncher.apk
touch -d @$ORIGTS android_sys/app
umount android_sys/
Now after I low format the device and flash everything back (including system.img) the device starts fine and boots up, system loads up fine, Launcher3 is used (no prompt for a default launcher).
The problem starts with subsequent boots, I have noticed following unwanted behavior:
1. sometimes the device boots to the system, but the top statusbar and bottom navbar are completely hidden, it is not possible to drag down the statusbar or use SW keys (home, back, ...)
2. device is stuck in booting animation.
My q is: can NovaLauncher be removed from system.img as it seems that its removal is causing some issues? Or do you think it is something else that can be causing this odd behavior (e.g. mangled system.img ext4 partition?)
2014/09/06 - 20:06
No, I guess you have some other things corrupted. Can I have a dmesg from a fresh boot?
onder7973
2014/09/08 - 10:11
Hi, after a very lengthy trial/error session, I found that the poblem was in a "corrupted" bootanimation.zip file. For some very odd reason, the tablet would end up in a boot loop if the animation was set this way:
1024 600 25
p 0 0 part0
And 50 png images in part0. Please note that the problem was not the png image format, but the number of images in an animation part. As soon as I used 53 images the problem was gone ... Surprised
Anyways, thanks for this custom ROM, works flawlessly so far. I noticed that there was a particular battery drain reported by 'Mobile Standby' so I removed the telephony service (since it is a WiFi tablet only) and the system is still stable so far.
2014/09/08 - 10:17
May I asked again for dmesg log? Thank you in anticipation!
onder7973
2014/09/08 - 10:47
Dmesg attached. Hope it helps.
The following users say thank you to onder7973 for this useful post:
Kennybobs
2014/10/24 - 02:26
Any instructions for using Linux?
2014/10/24 - 07:09
Linux on the tab or Linux to flash the build?
Kennybobs
2014/10/24 - 14:00
Hello!
Linux to flash the build.
Thanks Received: 3170
2014/10/24 - 14:49
For firmwares in full images format (update.img) you can use: Linux Upgrade Tool v1.21
For multiple images firmwares like OMA's packages, check the other tools: rkflashtool and the rkflashkit GUI:
http://wiki.radxa.com/Rock/flash_the_image
107 Guest(s)
Devices in use: Desktop (95), Phone (12)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
