[ ROM ] RoverPad TRC7 Android 4.2.2 Jelly Bean custom root firmware (2014/04/21)
Forgotten Tabs Project: this is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (& links to RTL8723, AR9271, NMC1000, MT7601, ESP8089 wifi).
pitouraswag
106
2015/10/22 - 13:15
Could you have a look at these please? So, maybe the orientation and touch issues I had with your rom lie somewhere in boot.img?
107
2015/10/22 - 16:51
I do see 3 posts from you with mostly no information of what your tab is and what you are trying to do. Maybe you can give a bit more information?
pitouraswag
108
2015/10/23 - 01:27
Yes, I am sorry.
My device is m07r6 (sold as Turbo-x Rubik 7 here in Greece.)
My question is: Are the files that I have suitable in order to return to stock? I have dumped them by using your directions, Oma7144. (I have kernel.img that you say is empty and also boot.img, recovery.img and system.img.)
Note: I have already installed this custom rom and the m07r6 kernel that you provide in the past and had touch and orientation issues. So I had to get the tablet to the manufacturer because the files that I had dumped the first time (before flashing the custom rom) were corrupted and I could not return to stock. They installed the stock firmware and everything is fine now.
109
2015/10/23 - 17:38
In the archive is kernel #277 preempt 12 March 2014: http://crewrktablets.arctablet.com/?wpfb_dl=2285
Turbo-X Rubik 7 has kernel #408 preempt 20 Sepember 2014: http://crewrktablets.arctablet.com/?wpfb_dl=2718
Best is you upload the complete dump incl. the logs, so that I can check if the Rover Pad build is the right one.
pitouraswag
110
2015/10/23 - 19:09
Here are the logs too. So you now only miss system.img. Do you need it too?
111
2015/10/23 - 19:21
No I don't need that, but I can check if the dump is ok.
Reboot tab and do the dmesg again. I need to see the log from 0.000000 sec.
pitouraswag
112
2015/10/23 - 19:32
What I did was: Boot, open Terminal Emulator, Write the command.
Here you are! (Thank you for your time..)
113
2015/10/23 - 19:42
Is wifi on? I cannot see the footprint of the chip.
pitouraswag
114
2015/10/23 - 20:26
With WiFi on.
115
2015/10/24 - 07:16
Current WiFi chip is RTL8188EU.
Ok, build from post #1 should work with the Rubik 7 kernel.
LionHell
116
2015/10/27 - 20:38
Hello Oma7144,
I have a Logicom S732 that I want to transform in Audio Player with Kodi. I wondered if it possible to add a kernel module to support usb optical drive like external cd ou dvd drive?
Yes I know everybody use music streaming today 😉 But I have a lot of music CD I want to play them with the tablet.
Thank in advance if you could add this support.
MarkWW
117
2015/10/31 - 19:09
I have Utok 701D and install this rom, on boot I see ROVERPAD image but nothing is happening.
STOCK FIRMWARE INFO:
Bootloader:unkown
Kernel:3.0.36+ zed@zed-desktop1 #136
Build Number:rk3026-eng 4.4.2 KOT49H eng.zed.20140923.203958 test-keys
BOARD:ZED zm726ce-A-MB-V1.1.1
RK3026 @ 1Ghz Dual Core
ARM Mali-400MP2
512 MB DDR3 RAM
8 GB ROM
samuk190
118
2015/11/18 - 04:09
 Hi, im new on this forum, i got a tablet, AVOCA STB7013
But its dead, on loop in LOGO
Now, i flashed your rom with the kernel  and loader of this device.
Black screen 🙁
what can i do?
Where i get the original firmware of this device? (Avoca website is down, avoca died)?
L1on
119
2016/05/21 - 15:10
Hi
You excuse me I have a Jay-tech Tablet PC 9000 model PA0906 and it is jammed on the logo of start where I could find a compatible rom ? thanks  in advance
83 Guest(s)
Devices in use: Desktop (73), Phone (10)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
