[ ROM ] RoverPad TRC7 Android 4.2.2 Jelly Bean custom root firmware (2014/04/21)
Forgotten Tabs Project: this is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (& links to RTL8723, AR9271, NMC1000, MT7601, ESP8089 wifi).
Drzony
92
2015/08/28 - 21:25
kernel 3.0.36+ (incar@incarsoft) #201 SMP PREEMPT Thu Jul 17 16:48:26 CST 2014
Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 3.41.WFD) init.
ro.build.display.id=rk3026_8931_8188_8312_3670_800x480_4.4.2_20140717.165304
ro.build.version.incremental=eng.incar.20140717.165009
ro.product.model=MID901
Here is the Manta MID901 kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2642
Try this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-vido-n70s-android-4-4-2-kitkat-custom-root-firmware-20140517/
Just change kernel in folder rockdev/Image before flash.
Drzony
93
2015/08/29 - 19:48
And if something goes wrong, how can I restore original FW? Just replace *.img files in rockdev/image with dumped files I uploaded?
94
2015/08/29 - 21:22
Yes, should work this way.
Drzony
95
2015/08/29 - 23:34
looks like I bricked my tablet.
After info "Download Image OK" i plugged out tablet from PC, and it's not reacting to power button...
When I plug it to PC there's a info about not recognizing USB device.
AndroidTool 2.1 says No Found Any Devices.
RIP in pieces Manta MID901 (*)... Or maybe not?
http://i.imgur.com/DFI2Nkk.png this is the log from flashing
96
2015/08/30 - 10:50
Hm, the dumped kernel.img is either empty or corrupted. Here is the kernel splitted from boot.img: http://crewrktablets.arctablet.com/?wpfb_dl=2642
Try again. Start the tab into flash modus via key combination.
Drzony
97
2015/08/30 - 13:32
yay, it works 😀 big thanks for your help!
Wifi works too. If i encounter any bugs I'll report them in your kitkat rom theard 🙂
also, how to flash CWM?
" c) load recovery_CWM"
how? 😀
You meant that?
http://i.imgur.com/DkfWrY5.pngImage Enlarger
I moved recovery_cmw.img to rockdev/image
98
2015/08/30 - 13:58
You can load files by ticking on the empty box at the end of the line.
Untick the loader before flash.
Drzony
99
2015/08/30 - 14:21
Everything works. Once again bug thanks for your time and help 🙂
modovich
100
2015/10/09 - 18:31
Flash was successfull on a 2 LOOK tablet. All works good.
Thank you Oma.
Just one question, is there any hope of a KitKat ROM for my device? I sent you my ROM build earlier.
101
2015/10/09 - 18:48
Fine. KK needs a selinux kernel, which is not available for your tab.
pitouraswag
102
2015/10/21 - 14:29
Hello,I try to dump the stock kernel with Terminal Emulator (with the method you provided) and I get a 12mb kernel.img. When I try to pack it with WinRar it is only 6kb. Do you think there's something going wrong?
Thanks Received: 3171
103
2015/10/21 - 14:44
The file looks quite "empty" and that explains the high compression ratio. The dump was probably done on the wrong partition.
Oma may provide you a more complete explanation and guidance Wink
pitouraswag
104
2015/10/21 - 14:58
Alright, thanks for your reply! I'll wait for Oma's guidance.
I just want to share that when I write on terminal "ls -al /dev/block/mtd/by-name" I get the partitions table and it seems like the kernel is indeed on mtdblock1.
Also, I would like to ask you if it is normal that all the dumped files have a whole number as size, for example 12mb or 700mb instead of 12.43mb or 713.76mb.
105
2015/10/21 - 19:41
Kernel.img is indeed empty. So we will find a kernel in boot.img and recovery.img.
177 Guest(s)
Devices in use: Desktop (166), Phone (11)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
