[ ROM ] RoverPad TRC7 Android 4.2.2 Jelly Bean custom root firmware (2014/04/21)
Forgotten Tabs Project: this is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (& links to RTL8723, AR9271, NMC1000, MT7601, ESP8089 wifi).
76
2015/03/18 - 16:17
Ok, looks good. Tab has Atheros wifi.
Try this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-cube-u25gt2-h-android-4-2-2-custom-root-firmware-20140622/
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2508
Just change the kernel in folder rockdev/Images and uncheck the loader before flash.
al-zaher
77
2015/05/16 - 23:08
please help me...... i have supertab r10 rockchib rk3026  i flashed him then it become working whithout screen...... do you have any soluation?????!!!!!!
78
2015/05/18 - 17:28
Every tab has it's own kernel (hardware abstraction layer). So, do not flash a strange firmware/kernel into the tab without having at least a backup of the kernel. Pls contact the retailer for the genuine firmware.
polfrank
79
2015/07/15 - 17:21
Hello Oma7144 and everyone else. Good job for all your work!
So, I have a rockchip tablet too. It's a 3026 and the model is m07r6. (It's sold as Turbo-X Rubik 7'' here in Greece.)
I install the 4.2.2 firmware and I replace the kernel.img with the one provided for m07r6 on the 2nd post.
It boots normally, but I have 2 problems:
1. Orientation is not working at all.
2. The touch is partially working. I touch the left side of the screen and the tablet feels like I'm touching the right side of the screen. When I touch the right side of the screen nothing happens. The same happens when I use TWRP.
Could you please help me?
ps. I cannot find the original firmware anywhere. Also, I didn't make a backup before flashing your custom rom. (my bad)
nielnamoc
80
2015/08/16 - 17:02
This is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (no Bluetooth).
The build is done for ROVERPAD SKY C70 RSP TR7C and will also boot on tabs named R88 (thanks to oss85 for testing) - ;-)
You will find further kernel in post#2.
Oma TRC7 JB v1.0
Oma TRC7 JB v1.1 (for tabs with rotations issues like Onn 07D)
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel guo #1
– internal storage 2,0 GB
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
hints:
– higher performance > disable animation scales in developer options
– don't show su notifications > disable in Superuser
- to prettify the build use Xposed Framework > Starter Pack
V17pro-1.pngImage Enlargerv1.0_01a-1.pngImage Enlargerv1.0_02-4.pngImage Enlargerv1.0_03-4.pngImage Enlargerv1.0_04-2.pngImage Enlarger
hi guru, just want to ask your opinion if this firmware will work on my tablet(tenko T7X mid7526 )but the only thing is it it has a 1024x600pxls resolution ..if ever this custom rom of yours will not work on my tab ,please give me hints or suggestions to find the right firmware ...this is the full specs :
RK3026
1.01GHz
cores :2
architecture :2xARM Cortex-A9@ 1.01GHz
revision :r4p1
process :40nm
clock speed :312mhz-1.01ghz
cpu 0 :816mhz
cpu 1 :816mhz
cpu load :
GPU vendor :ARM
GPU Renderer :mali-400mp
scaling govrnor :interactive
         SYSTEM
manfctr :tenko7526h
board :rk30sdk
bootloadr :unknown
build ID :1310785-788-TenkoT7X-20131210
hardware :rk30board
android vrsion :4.2.2
api lvl :17
java VM :dalvik 1.6.0
openGL ES :2.0
Kernel archt :armv7l
kernel vrsion :3.0.36+(eng.roger.20131210.111334)
screen size :11.23inchs
scrn rsolut'n(pxls) :1024x600
scrn dnsity :160pdi
total RAM :512mb
ntrnal storage : .98gb
root access :no
i flashed a wrong firmware on it so now it is completely dead ..
thanks and advance
81
2015/08/16 - 17:07
Every tab has it's specific kernel. Without this kernel no chance to recover the tab. Pls ask the manufacturer for a firmware link.
nielnamoc
82
2015/08/17 - 04:52
hi Guru Oma , i tried searching for the Manufacturer but coudnt find ,. Iforgot to say that it was already rooted with iroot so the build prop of that tablet has already a stain/changed ..if ever i could not find the stock kernel of it ,will it be restored through using rooted kernels ? For add info : it has chips named gsl1680 and rtl8188 ..
thanks in advance ..
83
2015/08/17 - 07:59
Doesn't work this way. A kernel (hardware abstraction layer) has to be compiled from source. So, never frash something strange into the tablet without having a fallback (stock firmware or a dump of the running firmware).
nielnamoc
nielnamoc
84
2015/08/19 - 08:47
guru its me again ,,,
hayyyy still couldnt find the manufacturer ..favor ,f u know a someone knows about tenko's manufacturer please bother update me ....thanks again
Drzony
85
2015/08/26 - 18:03
I have this tablet http://www.manta.com.pl/en/mid901
Image Enlarger
Can I use this rom? I see I need to change kernel, which one will work with my device?
edit: My device is working on KitKat out of box.
Drzony
87
2015/08/26 - 19:34
Is there another way to dump FW? I have this for about 10minites and nothing happend.
Image Enlarger
88
2015/08/26 - 20:51
Could be a driver issue. Anyway, you can do it on the tab. Hope it is already rooted.
Open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd > /mnt/sdcard/mtd.txt
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd9 of=/sdcard/system.img bs=4096
Drzony
89
2015/08/28 - 19:19
Sorry for making you wait, I had some problems with Internet connection. Here's zip with all txt and img files dumped.
https://mega.nz/#!fsQWHZ5Z!BgjaUtykzpPUJOO8Ojsc7Nl1p-YYwOvqpC_Puo8hK-s
90
2015/08/28 - 20:25
Can you pls reboot the tab and do the dmesg again? I need to see the log from 0.0000000 sec.
204 Guest(s)
Devices in use: Desktop (189), Phone (14), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
