[ ROM ] RoverPad TRC7 Android 4.2.2 Jelly Bean custom root firmware (2014/04/21)
Forgotten Tabs Project: this is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (& links to RTL8723, AR9271, NMC1000, MT7601, ESP8089 wifi).
Thanks Received: 3170
61
2015/01/13 - 17:37
xontab said
Can you please let me know how I can extract the following kernel (as it looks like it is not compatible with 7-zip - Windows version)?
Beneve i7 – http://crewrktablets.arctablet.com/?wpfb_dl=1962
I just checked the file, it has a 7zip header but I can't extract it as well, I tried with 7z and rar unpackers on Linux which works fine on other 7z files. I'm wondering if that file is damaged, maybe Oma will be able to check and re-upload if needed.
62
2015/01/13 - 21:26
Hm, 131 times downloaded and nobody states it is corrupted by now? Normal kernel zip file is about 2.5 MB this here has 316 KB.
Uploaded again. Sorry xontab
@admin: some issues while data migration?
xontab
63
2015/01/14 - 20:14
Thanks a lot :) ... Managed to download the kernel file.
florynel001
64
2015/01/27 - 13:14
 ROM Stock or Custom for jay-tech pa777 (pr7062) rk3026 Please.
eumar
65
2015/03/16 - 12:09
Mr.Oma, i have this problem.. everything was fine when i flashed this rom to my tablet, although different brand and specs in internal memory: internal=1gb , sd=2gb ..
everything was fine but wifi doesnt work, when i press the toggle it will just off automatically and it says wifi turning on.. but nothing is happening. plssss help me..Screenshot_2015-03-28-19-34-12.pngImage Enlarger
66
2015/03/16 - 17:00
Every tab has it's own kernel (hardware abstraction layer). So, what is your tab and is the stock firmware available?
eumar
67
2015/03/17 - 05:44
sir. stock firmware is not available. i have only cwm back up. i have extracted teh system file but i dont know how to make it into system img and im only running windows. im noob in linux
eumar
68
2015/03/17 - 05:47
i mean system folder..  my tablet is royqueen RQ713r, 4.2.2
69
2015/03/17 - 05:48
Pls upload the backup. I will check.
eumar
70
2015/03/17 - 05:50
okay sir. ill send the link to you later. thank you so much..
eumar
71
2015/03/17 - 05:53
sir oma? is it okay if i will not include to zip the data.ext file? because its so large. 400mb+ just data.
72
2015/03/17 - 05:56
Boot, kernel, recovery and system.
eumar, mareu
eumar
73
2015/03/17 - 05:58
thank you so much..
eumar
74
2015/03/17 - 23:21
here is it sir oma. Sorry for the delay, i have bad internet connection..
http://www.mediafire.com/download/wv033dk0ypptmox/2015-02-08.16.19.50.rar
The following users say thank you to eumar for this useful post:
mareu
eumar
75
2015/03/18 - 07:36
65 Guest(s)
Devices in use: Desktop (56), Phone (9)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
