[ ROM ] RoverPad TRC7 Android 4.2.2 Jelly Bean custom root firmware (2014/04/21)
Forgotten Tabs Project: this is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (& links to RTL8723, AR9271, NMC1000, MT7601, ESP8089 wifi).
pask
46
2014/11/17 - 12:39
Ok, no kernel event means they have patched the kernel against Android, instead of doing it right in Android ...
Just guessing, could be crash the build: http://crewrktablets.arctablet.com/?wpfb_dl=2241
the tablet remains on the boot screen
47
2014/11/17 - 12:46
Ok, then no chance to do it that way. When times allows I will do a complete build based on Logicom stock.
pask
48
2014/11/17 - 12:48
ok! thak you very much!
pask
50
2014/11/17 - 23:13
Can you pls test? http://crewrktablets.arctablet.com/?wpfb_dl=2243
thanks for your quick work but the rotation doesn't work. androsensor - acceleromiter: waiting for event
pask
51
2014/11/18 - 00:28
pask said
the device doesn't read external sd card
52
2014/11/18 - 13:10
Hm, are there different hardware revisions? Where can I find your working stock firmware?
pask
53
2014/11/18 - 15:04
I don't know where i or you can find stock firmware, my device is logicom s732 (m711r), i try to find it but noting.
I restored Oma_RK3026_Roverpad TRC7_JB_4.2.2_v1.0 with RK3026_kernel_3036_s732_logicom, i have good performance with this configuration, while with Oma_RK3026_Logicom_S732_JB_4.2.2_v1.0 i had more lag, therefore, at this point, I can renounce the rotation.
thank a lot.
billkaza
54
2014/11/19 - 13:29
Hello i have managed to brick my beneve r70AC device with following specs..
http://www.dx.com/p/beneve-r70ac-7-dual-core-android-4-2-2-tablet-pc-w-16gb-rom-3g-wi-fi-tf-g-sensor-orange-320816#.VGyJaWcsHFI
All i can is volume up + power and see it to rkandroid tools.
But i cant open rkandroid tool(i get error cant load config file) from this rom you have posted only a rkandroid tool that i have used to mod my chuwi v17hd
I use this tool and flash the image but nothing only black screen..
Have you got any proposal?
kennyrogers
55
2014/11/30 - 18:37
I have a very strange tablet, AKAI JK-710 which I found to be also MYRIA JK-710. Unfortunatelly, I rushed in and burnt your firmware (Oma_RK3026_Roverpad TRC7_JB_4.2.2_v1.1) with default loader (RK3026Loader(L)_V2.09.bin) and the stock kernel. There I stumbled, white screen flicker and then black screen. I found then a kernel that worked which I found also on your website (http://crewrktablets.arctablet.com/?page_id=4051) , kernel for JEKA JK 702. Now I`m stuck on OMA screen loader with animation. The hardware is pretty much common (RK 3026, 512 RAM, 800x480, one front camera), wireless chipset is for sure RTL8188 ( I dumped the logs but dumb me, haven`t copyed them on sdcard so they`re lost). I know I provide scarce informations, but any thoughts about how can I pass the loading animated screen ? Thanks !
kennyrogers
57
2014/11/30 - 19:58
Thanks but I`m sure wireless is RTL8188. I made some progress, tried again with the Oma_RK3026_Roverpad TRC7_JB_4.2.2_v1.1 with a random kernel (Acho Mid 7) I suppose, and manage to boot upto desktop but touch screen not working ! :) I guess I have a long night before me testing every and each kernel you posted !
58
2014/11/30 - 20:01
No. Use an usb-mouse and try wifi first. Then let me have a dmesg log.
indush
59
2014/12/16 - 07:41
im searching for a Firmware for The tablet Nero G-Tab Cx2
has c88/131116/v10 on the board and I need the stock rom or any one that works with it! its developed By MATRICOM
The CPU is Rockchip RK3026 please any help, it was flashed with wrong software and now it cant be detected by Rk tool, but its get recognized by the PC as Rockchip. Once time it told me about Rockchip mask need loader file or something like that... Frown
xontab
60
2015/01/13 - 17:22
For testing pls find below the following kernel (change in folder rockdev/Images before flashing):
HY76 - http://crewrktablets.arctablet.com/?wpfb_dl=1701
Cube U25GT2-F - http://crewrktablets.arctablet.com/?wpfb_dl=1716
Acho Mid 7 - http://crewrktablets.arctablet.com/?wpfb_dl=1700
Vido N70S DZ - http://crewrktablets.arctablet.com/?wpfb_dl=1706
Onn 07D - http://crewrktablets.arctablet.com/?wpfb_dl=1728  >>> see post #15
Odys Ace - http://crewrktablets.arctablet.com/?wpfb_dl=1748
FreeTab 2096+ x2 - http://crewrktablets.arctablet.com/?wpfb_dl=1776
Ceros Create - http://crewrktablets.arctablet.com/?wpfb_dl=1835
MID Mid - http://crewrktablets.arctablet.com/?wpfb_dl=1952
Wintouch R74 - http://crewrktablets.arctablet.com/?wpfb_dl=1953
ICCO D10m 10" - http://crewrktablets.arctablet.com/?wpfb_dl=1964
Logicom S732 - http://crewrktablets.arctablet.com/?wpfb_dl=2009
Leaderpad Brazuca2 - http://crewrktablets.arctablet.com/?wpfb_dl=2020  >>> confirmed installation as is
Dragontouch R70 - http://crewrktablets.arctablet.com/?wpfb_dl=2054
Alterego Kids Tab - http://crewrktablets.arctablet.com/?wpfb_dl=2058
3Q RC734H - http://crewrktablets.arctablet.com/?wpfb_dl=2186
For the following tabs you need to change the Loader, too: http://crewrktablets.arctablet.com/?wpfb_dl=1723
Cube U25GT2-W - http://crewrktablets.arctablet.com/?wpfb_dl=1717
Vido N70S CZ - http://crewrktablets.arctablet.com/?wpfb_dl=1707
Apad R70DC (Kid tab) - http://crewrktablets.arctablet.com/?wpfb_dl=1715
Avoca STB7013 - http://crewrktablets.arctablet.com/?wpfb_dl=1709
ICOO D70m - http://crewrktablets.arctablet.com/?wpfb_dl=1705
ICCO D90m 9" - http://crewrktablets.arctablet.com/?wpfb_dl=1720
Beneve i7 - http://crewrktablets.arctablet.com/?wpfb_dl=1962
ifive 100 - http://crewrktablets.arctablet.com/?wpfb_dl=1699
>>> Tabs with RTL8723 wifi (and BT) see Odys Bravio thread
>>> Tabs with Atheros AR9271 wifi see Cube U25GT2-H thread
>>> Tabs with NMC1000 and MT7601 wifi see V17pro thread
Before flash anything into the tab pls make sure you have the genuine firmware as a fall-back position.
Can you please let me know how I can extract the following kernel (as it looks like it is not compatible with 7-zip - Windows version)?
Beneve i7 – http://crewrktablets.arctablet.com/?wpfb_dl=1962
74 Guest(s)
Devices in use: Desktop (65), Phone (9)
heydude
Varnanfilms
jacklewis3
123456asd
valdes1964
pipo2015max
