Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2118
2014/09/14
OMA, I'm sorry again ... I have a problem on this firmware when you open the File Manager continuously writes, "is not inserted SD-card." In the file manager on the map visible. It is impossible to reproduce music from SD-card, open a photo, upload a file from the Internet - says there is no SD-card. Formatting does not help. The use of other cards too. On other Android devices using this SD-card is no problem - the map and see the files. What can be done?
This indicates a not properly formatted NAND. Goto settings and do a factory reset.
2014/10/16
hello. i am new here.
I dont know if this will be any help to you, i have an "INTENSO TAB 734" i open it up and the board inside is a "M7100KLD v1.4" like Onn 07D and has a 3026 processor.
I would like to report that i test your rom with the " Onn 07D " kernel and worked. i believe they're the same
if it helps, in there site they have some sources.
Thanks for your great job, and sorry for my rusty English.
The following users say thank you to frappes for this useful post:
Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2233
2014/11/16
Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2233- Oma -
thanks, but this solution doesn't work, sensorcontrol.default.so and sensors.rk30board.so were correctly load but if i want to change screen orientation, i must go in nova settings.
Can you pls check with Androsensor (Play Store) if there is activity or if it shows no event.
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2240
2014/11/16
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2240- Oma -
it doesn't work. accelerometer - waiting for event
Ok, no kernel event means they have patched the kernel against Android, instead of doing it right in Android ...
Just guessing, could be crash the build: http://crewrktablets.arctablet.com/?wpfb_dl=2241
88 Guest(s)
Devices in use: Desktop (72), Phone (15), Tablet (1)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
