[ ROM ] RoverPad TRC7 Android 4.2.2 Jelly Bean custom root firmware (2014/04/21)
Forgotten Tabs Project: this is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (& links to RTL8723, AR9271, NMC1000, MT7601, ESP8089 wifi).
Homerchic
Forum Posts: 12
2014/09/14 - 20:50
Dear OMA! Flashed your tablet teXet your firmware. Nothing else came up. Everything works fine, one problem with the rotation of the screen (DaremoS post # 5). Can anything be done? Here sensors.rk30board with native firmware teXet. Or is it nothing can help?
Homerchic
Forum Posts: 12
2014/09/14 - 21:44
Sorry, nothing has changed ...
2014/09/14 - 21:49
Ok, pls describe a bit. No rotation at all? Or just a missmatch of 90 degree clockwise/counterclockwise?
Homerchic
Forum Posts: 12
2014/09/14 - 22:06
http://i.imgur.com/YI0PHVv.jpgImage Enlarger
http://i.imgur.com/BU8xwS3.jpgImage Enlarger
2014/09/14 - 22:13
Ok, download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2103
Homerchic
Homerchic
Forum Posts: 12
2014/09/14 - 22:17
If you hold the tablet horizontally - all ok
If vertically - on the contrary
2014/09/14 - 22:48
I cannot understand that guys patch the kernel (mirror y-axis) instead of simply do it right in Android.
Where can I find the stock firmware?
Homerchic
Forum Posts: 12
2014/09/14 - 22:59
This Problem is, I never found the drain firmware from it. The official website of teXet refused to give it to me. Therefore, I ask your. Okay, so very good)))
http://i.imgur.com/HCkppVm.jpgImage Enlarger
http://i.imgur.com/tPkYqsQ.jpgImage Enlarger
http://i.imgur.com/X2FivEZ.jpgImage Enlarger
Homerchic
Forum Posts: 12
2014/09/14 - 23:00
Thank you very much !!!
2014/09/19 - 21:45
Just guessing what your kernel is doing. Can you pls test this build with your kernel?
http://crewrktablets.arctablet.com/?wpfb_dl=2115
Homerchic
Homerchic
Forum Posts: 12
2014/09/20 - 05:35
Dear OMA! Everything works fine !!! Screen rotates as it should. Thank you very much, I am delighted !!!
P.S Forgot to say, kernel I take as before: Onn 07D - otherwise not working ...
2014/09/20 - 06:19
Cool.
What is the problem with the teXet kernel?
Homerchic
Forum Posts: 12
2014/09/20 - 06:31
If you put the firmware of 1 post - the tablet does not boot, black screen until loading kernel Onn 07D.
And when you install the firmware v1.1 - white screen. After loading the kernel Onn 07D - all excellent!
2014/09/20 - 06:36
Yeah, every tab has its specific kernel. When the Onn kernel works on your teXet, then the tabs are highly identical.
85 Guest(s)
Devices in use: Desktop (74), Phone (11)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
