This is an approch to provide a generic build for older rk3026boards with RTL8188 wifi (no Bluetooth).
The build is done for ROVERPAD SKY C70 RSP TR7C and will also boot on tabs named R88 (thanks to oss85 for testing) -
You will find further kernel in post#2.
Oma TRC7 JB v1.1 (for tabs with rotations issues like Onn 07D)
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel guo #1
– internal storage 2,0 GB
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
hints:
– higher performance > disable animation scales in developer options
– don't show su notifications > disable in Superuser
- to prettify the build use Xposed Framework > Starter Pack
Homerchic, songokuy, aydin.gsm1Per aspera ad astra, we rock the Tablets !
For testing pls find below the following kernel (change in folder rockdev/Images before flashing):
HY76 - http://crewrktablets.arctablet.com/?wpfb_dl=1701
Cube U25GT2-F - http://crewrktablets.arctablet.com/?wpfb_dl=1716
Acho Mid 7 - http://crewrktablets.arctablet.com/?wpfb_dl=1700
Vido N70S DZ - http://crewrktablets.arctablet.com/?wpfb_dl=1706
Onn 07D - http://crewrktablets.arctablet.com/?wpfb_dl=1728 >>> see post #15
Odys Ace - http://crewrktablets.arctablet.com/?wpfb_dl=1748
FreeTab 2096+ x2 - http://crewrktablets.arctablet.com/?wpfb_dl=1776
Ceros Create - http://crewrktablets.arctablet.com/?wpfb_dl=1835
MID Mid - http://crewrktablets.arctablet.com/?wpfb_dl=1952
Wintouch R74 - http://crewrktablets.arctablet.com/?wpfb_dl=1953
ICCO D10m 10" - http://crewrktablets.arctablet.com/?wpfb_dl=1964
Logicom S732 - http://crewrktablets.arctablet.com/?wpfb_dl=2009 >>> see post #49
Leaderpad Brazuca2 - http://crewrktablets.arctablet.com/?wpfb_dl=2020 >>> confirmed installation as is
Dragontouch R70 - http://crewrktablets.arctablet.com/?wpfb_dl=2054
Alterego Kids Tab - http://crewrktablets.arctablet.com/?wpfb_dl=2058
3Q RC734H - http://crewrktablets.arctablet.com/?wpfb_dl=2186
3Q RC719H - http://crewrktablets.arctablet.com/?wpfb_dl=2207
yk86v - http://crewrktablets.arctablet.com/?wpfb_dl=2211
GT-N9000 - http://crewrktablets.arctablet.com/?wpfb_dl=2281
M07R6 - http://crewrktablets.arctablet.com/?wpfb_dl=2285
Vido T10 DZ - http://crewrktablets.arctablet.com/?wpfb_dl=2286
TeXet Sky 7032 TM - http://crewrktablets.arctablet.com/?wpfb_dl=2292
Smart Tech Tab 908DC - http://crewrktablets.arctablet.com/?wpfb_dl=2312
Aurotech M12xt - http://crewrktablets.arctablet.com/?wpfb_dl=2317
Suomai R70DC - http://crewrktablets.arctablet.com/?wpfb_dl=2334
Venstar K7 - http://crewrktablets.arctablet.com/?wpfb_dl=2340
yx101 - http://crewrktablets.arctablet.com/?wpfb_dl=2409
Sosoon X18 - http://crewrktablets.arctablet.com/?wpfb_dl=2410
i-Life Kids Tab 4 - http://crewrktablets.arctablet.com/?wpfb_dl=2445 >>> see here
3Q RC743H - http://crewrktablets.arctablet.com/?wpfb_dl=2444
Blow Black Tab10 II - http://crewrktablets.arctablet.com/?wpfb_dl=2438 >>> see here
For the following tabs you need to change the Loader, too: http://crewrktablets.arctablet.com/?wpfb_dl=1723
Cube U25GT2-W - http://crewrktablets.arctablet.com/?wpfb_dl=1717
Vido N70S CZ - http://crewrktablets.arctablet.com/?wpfb_dl=1707
Apad R70DC (Kid tab) - http://crewrktablets.arctablet.com/?wpfb_dl=1715
Avoca STB7013 - http://crewrktablets.arctablet.com/?wpfb_dl=1709
ICOO D70m - http://crewrktablets.arctablet.com/?wpfb_dl=1705
ICCO D90m 9" - http://crewrktablets.arctablet.com/?wpfb_dl=1720
Beneve i7 - http://crewrktablets.arctablet.com/?wpfb_dl=1962
ifive 100 - http://crewrktablets.arctablet.com/?wpfb_dl=1699
xk86v - http://crewrktablets.arctablet.com/?wpfb_dl=2212
>>> Tabs with RTL8723 wifi (and BT) see Odys Bravio thread
>>> Tabs with Atheros AR9271 wifi see Cube U25GT2-H thread
>>> Tabs with NMC1000 and MT7601 wifi see V17pro thread
>>> Tabs with ESP8089 wifi see Nameless 2 Euro Promotion Tab thread
Before flash anything into the tab pls make sure you have the genuine firmware as a fall-back position.
Your rom, as usual, work fine in my Onn 07D (Yifang M7100KLD), using the kernel you posted.
Only drawback is that is turned 90° I'll try to fix it in build.prop (If you put the parameter there, if not kindly tell me how how can I fix it).
Now is in tests and I let you know if I found something wrong.
One things is great for the moment, screen design is better that the android 4.2.2 that comes with the tablet (was an android for tablet with buttons in center and status on top).
I've installed TWRP recovery 2.7.0.0 (from here) for testing purposes. Is touch and a bit slow. I'll let you know.
I try first with your rom KitKat (Oma KitKat build v1.1) and it wasn't capable to go further than kernel screen, probably is for a different type of screen. At least different than your rom for TRC7.
Tablet Master-G G-820c (Yifang M900HC) 8" - RK2918
Tablet Onn 07HD (Yifang M7000NBD) 7"- AML8726-MXS
Tablet Onn 07DX (Yifang M7000KD) 7" - RK3066
Tablet Onn 07D (Yifang M7100KLD) 7"- RK3026
Phablet Samsung Galaxy Note 3
Cellphone Samsung Galaxy Trend
Turned in which direction?
KitKat not possible without selinux kernel.
- Om a-
Ok, seems to be we need the sensors.rk30board.so from the stock build.
Ok, seems to be we need the sensors.rk30board.so from the stock build.- Oma -
Here is such module taken from original build, sensors.rk30board.so named as sensors.rk30board.txt, just rename it.
Or you can tell me how can I insert this in the tablet, if it's possible.
Ok, first try: http://crewrktablets.arctablet.com/?wpfb_dl=1743Install via CWM.
Done.
Unfortunately didn't work... nothing changed.
Do you think I can try the other rom for 4.2.2 (Chuwi V17pro Android 4.2.2 Jelly Bean custom root firmware (2014/04/18))... which is better?
Another question what is a SELinux kernel?
Ok, the we need to look under the hood![]()
Pls upload the system.img and a dmesg log.
...- Oma -
I did a dump some time ago... it's complete here
Enclosed dmesg.txt
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1743
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1743- Oma -
¿Have you made a new version?
The one you posted and the fix are the same as before.
No, only the name is the same. Pls test.
No, only the name is the same. Pls test.- Oma -
Ok I've done what you suggest.
1. Downloaded Oma TRC7 JB v1.0 from post 1 of this thread,
2. Downloaded kernel Onn 07D – http://crewrktablets.arctablet.com/?wpfb_dl=1728 from post 2, used in flash,
3. Downloaded fix http://crewrktablets.arctablet.com/?wpfb_dl=1743 from post 12 above, installed via CWM,
4. Instructions followed strictly from package.
Rom run great... with problems in rotation.
Result:
Landscape displayed fine.
Portrait displayed turned 180°
Thanks for your time
71 Guest(s)
Devices in use: Desktop (62), Phone (9)
