This is an approch to provide a generic build for rk3026boards with rtl8723 wifi.
The build is done for Odys Bravio (thanks to freibergisch for providing the stock image and testing) –
You will find further kernel in post#2.
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel huang #21
– large userdata partition
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
hints:
– higher performance > disable animation scales in developer options
– don't show su notifications > disable in Superuser
- to prettify the build use Xposed Framework > Starter Pack
For testing on other tabs with RTL8723 wifi pls find below the following kernel (change in folder rockdev/Images before flashing):
GoTab GTD7 - http://crewrktablets.arctablet.com/?wpfb_dl=1710
Odys JuniorTab - http://crewrktablets.arctablet.com/?wpfb_dl=1747
Before flash anything into the tab pls make sure you have the genuine firmware as a fall-back position.
No, GTD7 kernel is for GTD7 tab
It is also RTL8723 wifi.
I have a strange rk3026 tablet for som months ago
it is dead, stuck at boot logo, it has been impossible to find the original ROM.
I will give this ROm a shoot and will repòrt back if it succed.
The board reads ak47_bt_v2.0 which returned no results for me searching a firmware for it.
it is brand tufsen
am not requesting for a firmware in this thread, just commenting out, and maybe someone has tried already the rom in this tablet.
if there is a better recommendation, it will be welcome
Currently Online: karenminton
90 Guest(s)
Devices in use: Desktop (87), Phone (4)
ronaldjw
Vladik
Nadie_Enn
DuzTab
dreho
ryddick
