[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
121
2015/06/04 - 18:15
Download a Terminal Emulator from Play Store. Reboot the tab, plug an usb device on and off a few times and then type:
su
dmesg >/mnt/sdcard/dmesg.txt
Copy the log to PC and upload it here.
soloprova
Forum Posts: 13
122
2015/06/04 - 19:00
I put it under the spoiler so do not post it invades everything.
thanks
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.0.36+ (yudongsheng@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #445 SMP PREEMPT Tue Nov 25 20:09:45 CST 2014
<4>[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ 0.000000] Machine: RK30board
<6>[ 0.000000] memory reserve: Memory(base:0x7fb00000 size:5M) reserved for <fb0 buf>
<6>[ 0.000000] memory reserve: Memory(base:0x7ab00000 size:80M) reserved for <ion>
<6>[ 0.000000] memory reserve: Memory(base:0x7a500000 size:6M) reserved for <camera_ipp_mem>
<6>[ 0.000000] memory reserve: Total reserved 91M
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[ 0.000000] bootconsole [earlycon0] enabled
<4>[ 0.000000] CPU SRAM: copied sram code from c0b0d000 to fef00010 - fef01a38
<4>[ 0.000000] CPU SRAM: copied sram data from c0b0ea28 to fef01a38 - fef01c38
<4>[ 0.000000] rk2928_clock_data_init version: 2013-7-17
<6>[ 0.000000] rk3026 soc version:4
<6>[ 0.000000] L310 cache controller enabled
<6>[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c9, AUX_CTRL 0x76030001, Cache size: 262144 B
<4>[ 0.000000] DDR DEBUG: version 1.00 20130731
<4>[ 0.000000] DDR DEBUG: 2 CS, ROW=14, Bank=8, COL=10, Total Capability=512MB
<4>[ 0.000000] DDR DEBUG: init success!!! freq=300MHz
<4>[ 0.000000] DDR DEBUG: left channel:Dllsel=3, Ophsel=1, Cycsel=1
<4>[ 0.000000] DDR DEBUG: right channel:Dllsel=3, Ophsel=1, Cycsel=1
<4>[ 0.000000] DDR DEBUG: DRV Pull-Up=0x1, DRV Pull-Dwn=0x4
<4>[ 0.000000] DDR DEBUG: ODT Pull-Up=0x0, ODT Pull-Dwn=0x0
<4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 107776
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0b0a360, node_mem_map c0000000
<7>[ 0.000000] Normal zone: 976 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 106800 pages, LIFO batch:31
<4>[ 0.000000] HighMem zone: 48 pages exceeds realsize 0
<6>[ 0.000000] PERCPU: Embedded 7 pages/cpu @c15b4000 s6976 r8192 d13504 u32768
<7>[ 0.000000] pcpu-alloc: s6976 r8192 d13504 u32768 alloc=8*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 106800
<5>[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00120000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00008000@0x0000A000(boot),0x00010000@0x00012000(recovery),0x00020000@0x00022000(backup),0x00040000@0x00042000(cache),0x00400000@0x00082000(userdata),0x00002000@0x00482000(kpanic),0x00100000@0x00484000(system),-@0x00584000(user) bootver=2013-12-16#2.09 firmware_ver=4.2.2
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] Memory: 421MB = 421MB total
<5>[ 0.000000] Memory: 407252k/407252k available, 117036k reserved, 0K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
<5>[ 0.000000] vmalloc : 0xdf000000 - 0xfe800000 ( 504 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xde800000 ( 488 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .init : 0xc0408000 - 0xc0495000 ( 564 kB)
<5>[ 0.000000] .text : 0xc0495000 - 0xc0aa62ac (6213 kB)
<5>[ 0.000000] .data : 0xc0aa8000 - 0xc0b0c1c8 ( 401 kB)
<5>[ 0.000000] .bss : 0xc0b0f024 - 0xc15b26f8 (10894 kB)
<6>[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:320
<4>[ 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
<6>[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<4>[ 0.000000] rk_timer: version 1.3
<6>[ 0.003801] Calibrating delay loop (skipped) preset value.. 1199.60 BogoMIPS (lpj=5998045)
<6>[ 0.012991] pid_max: default: 32768 minimum: 301
<6>[ 0.018425] Mount-cache hash table entries: 512
<6>[ 0.024253] Initializing cgroup subsys debug
<6>[ 0.029038] Initializing cgroup subsys cpuacct
<6>[ 0.034081] Initializing cgroup subsys freezer
<6>[ 0.039079] CPU: Testing write buffer coherency: ok
<4>[ 0.142498] CPU1: Booted secondary processor
<6>[ 0.142556] Brought up 2 CPUs
<6>[ 0.150677] SMP: Total of 2 processors activated (2399.21 BogoMIPS).
<6>[ 0.158224] devtmpfs: initialized
<6>[ 0.168729] NET: Registered protocol family 16
<6>[ 0.173854] last_log: 0xda100000 map to 0xdf004000 and copy to 0xc0b104e0 (version 2.1)
<4>[ 0.198624] DVFS MSG: AVS Value(index=0): 234 234 234 234 234 234 234 234 234 234
<6>[ 0.218925] lcdc0 is used as primary display device contoller!
<6>[ 0.225473] warning:lcdc1 not add to system!
<6>[ 0.330523] rk29sdk_wifi_bt_gpio_control_init: init finished
<6>[ 0.338204] console [ttyFIQ0] enabled, bootconsole disabled
<6>[ 0.347387] Registered FIQ tty driver da089c00
<6>[ 0.348066] Loaded driver for PL330 DMAC--1 rk29-pl330
<6>[ 0.348117] DBUFF-64x8bytes Num_Chans-8 Num_Peri-14 Num_Events-16
<6>[ 0.348252] rk29xx_spim: clk_get for spi (48000000)
<6>[ 0.373773] rk29xx_spim: driver initialized, fifo_len=32,bus_num=0
<6>[ 0.389875] bio: create slab <bio-0> at 0
<5>[ 0.394437] SCSI subsystem initialized
<6>[ 0.394720] usbcore: registered new interface driver usbfs
<6>[ 0.394859] usbcore: registered new interface driver hub
<6>[ 0.409038] usbcore: registered new device driver usb
<6>[ 0.409441] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
<6>[ 0.409735] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
<6>[ 0.435460] rk30-adc rk30-adc: rk30 adc: driver initialized
<4>[ 0.808461] protection lower power .....
<6>[ 0.812431] rk30_adc_battery: driver initialized
<6>[ 0.817342] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[ 0.824311] Bluetooth: Core ver 2.16
<6>[ 0.828036] NET: Registered protocol family 31
<6>[ 0.832525] Bluetooth: HCI device and connection manager initialized
<6>[ 0.838947] Bluetooth: HCI socket layer initialized
<6>[ 0.843864] Bluetooth: L2CAP socket layer initialized
<6>[ 0.848972] Bluetooth: SCO socket layer initialized
<6>[ 0.854158] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.861718] rk fb probe ok!
<6>[ 0.864632] Switching to clocksource rk_timer
<6>[ 0.871825] Switched to NOHz mode on CPU #0
<6>[ 0.872554] Switched to NOHz mode on CPU #1
<4>[ 0.886283] lcdc0:reg_phy_base = 0x1010e000,reg_vir_base:0xdf0a0000
<4>[ 0.892684] fb0:win0
<4>[ 0.892691] fb1:win1
<4>[ 0.892697] fb2:win2
<4>[ 0.899322] rk3188 lcdc0 clk enable...
<4>[ 0.928135] rk3188 lcdc0 clk disable...
<4>[ 0.941232] fb0:phy:7fb00000>>vir:df800000>>len:0x500000
<4>[ 0.946876] rk_fb_register>>>>>fb0
<4>[ 0.950658] rk_fb_register>>>>>fb1
<4>[ 0.954113] rk3188 lcdc0 clk enable...
<4>[ 0.957911] lcdc0: dclk:33000000>>fps:60
<6>[ 0.961785] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
<6>[ 0.968272] lcdc0 wakeup from standby!
<6>[ 0.972054] lcdc0 win0 open,atv layer:1
<4>[ 0.976731] rk3188 lcdc0 probe ok!
<4>[ 0.980348] pwm_regulator_probe:n_voltages=25,dcdc->desc.name=PWM_DCDC1,dcdc->desc.id=0 pwm_id=1
<4>[ 0.989383] pwm_regulator_probe dcdc1 =dcdc
<6>[ 0.993704] pwm_regulator.0: driver initialized
<6>[ 0.993715] ,dcdc->suspend_hrc=e,dcdc->suspend_lrc=12
<6>[ 0.993727]
<4>[ 1.014891] pwm_regulator_probe:n_voltages=25,dcdc->desc.name=PWM_DCDC2,dcdc->desc.id=1 pwm_id=255
<4>[ 1.024056]
<4>[ 1.024061]
<4>[ 1.024066] ************************************************
<4>[ 1.032740] ****pwm_regulator_probe PWM0: logic as same as arm
<4>[ 1.038615] ************************************************
<4>[ 1.038628]
<6>[ 1.045806] pwm_regulator.1: driver initialized
<6>[ 1.045818] ,dcdc->suspend_hrc=e,dcdc->suspend_lrc=12
<6>[ 1.045829]
<3>[ 1.058191] emmc emmc: internal_storage is NOT emmc
<6>[ 1.063324] NET: Registered protocol family 2
<6>[ 1.067876] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 1.075270] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
<6>[ 1.082884] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
<6>[ 1.089912] TCP: Hash tables configured (established 16384 bind 16384)
<6>[ 1.096485] TCP reno registered
<6>[ 1.099661] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 1.105555] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 1.112256] NET: Registered protocol family 1
<4>[ 1.319267] RK29 Backlight Driver Initialized.
<6>[ 1.323976] Unpacking initramfs...
<6>[ 1.397402] Freeing initrd memory: 1152K
<6>[ 1.401478] PMU: registered new PMU device of type 0
<4>[ 1.406590] efuse_version_val: efuse version = 41
<4>[ 1.411347] DVFS MSG: core_pre: dvfs_adjust_table_lmtvolt get leakage_level = 4000
<4>[ 1.418973] efuse_version_val: efuse version = 41
<4>[ 1.423735] DVFS MSG: gpu_pre: dvfs_adjust_table_lmtvolt get leakage_level = 4000
<4>[ 1.431633] rk3188 cpufreq version 2.2, suspend freq 312 MHz
<4>[ 1.438518] highmem bounce pool size: 64 pages
<6>[ 1.442033] ashmem: initialized
<6>[ 1.448826] fuse init (API version 7.16)
<6>[ 1.450874] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 1.450944] io scheduler noop registered
<6>[ 1.450981] io scheduler deadline registered
<6>[ 1.451097] io scheduler cfq registered (default)
<6>[ 1.460799] rga: Driver loaded succesfully
<4>[ 1.461064] rk_serial.c v1.4 2013-06-21
<6>[ 1.461206] rk_serial.0: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0
<6>[ 1.461458] rk_serial rk_serial.0: membase 0xdf09e000
<6>[ 1.461839] Rockchip ion module(version: 1.0) is successfully loaded
<6>[ 1.465201] loop: module loaded
<6>[ 1.465281] Android kernel panic handler initialized (bind=kpanic)
<6>[ 1.466317] PPP generic driver version 2.4.2
<6>[ 1.466549] PPP Deflate Compression module registered
<6>[ 1.466595] PPP BSD Compression module registered
<6>[ 1.467473] PPP MPPE Compression module registered
<6>[ 1.467521] NET: Registered protocol family 24
<6>[ 1.467664] usbcore: registered new interface driver asix
<6>[ 1.467757] usbcore: registered new interface driver cdc_ether
<6>[ 1.467848] usbcore: registered new interface driver dm9620
<6>[ 1.467938] usbcore: registered new interface driver SR9700_android
<6>[ 1.468046] usbcore: registered new interface driver net1080
<6>[ 1.468137] usbcore: registered new interface driver cdc_subset
<6>[ 1.468226] usbcore: registered new interface driver zaurus
<6>[ 1.468291] cdc_ncm: 04-Aug-2011
<6>[ 1.468365] usbcore: registered new interface driver cdc_ncm
<4>[ 1.468412] Rockchip WiFi SYS interface (V1.00) ...
<6>[ 1.468501] Initializing USB Mass Storage driver...
<6>[ 1.468605] usbcore: registered new interface driver usb-storage
<6>[ 1.468656] USB Mass Storage support registered.
<6>[ 1.468867] usbcore: registered new interface driver usbserial
<6>[ 1.468954] USB Serial support registered for generic
<6>[ 1.469047] usbcore: registered new interface driver usbserial_generic
<6>[ 1.469327] usbserial: USB Serial Driver core
<6>[ 1.469433] USB Serial support registered for GSM modem (1-port)
<6>[ 1.469585] usbcore: registered new interface driver option
<6>[ 1.469636] option: v0.7.2:USB Driver for GSM modems
<4>[ 1.469780] ~~~~~~~~~~usb20otg_soft_reset
<6>[ 1.683704] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
<6>[ 1.683778] usb20_otg usb20_otg: DWC OTG Controller
<6>[ 1.683971] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
<6>[ 1.684078] usb20_otg usb20_otg: irq 42, io mem 0x00000000
<6>[ 1.684131] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
<6>[ 1.684264] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.684330] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.684396] usb usb1: Product: DWC OTG Controller
<6>[ 1.684442] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
<6>[ 1.684495] usb usb1: SerialNumber: usb20_otg
<6>[ 1.685176] hub 1-0:1.0: USB hub found
<6>[ 1.685230] hub 1-0:1.0: 1 port detected
<6>[ 1.686262] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf180000
<6>[ 1.899951] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 1.899998] usb20_host usb20_host: DWC OTG Controller
<6>[ 1.900081] usb20_host usb20_host: new USB bus registered, assigned bus number 2
<6>[ 1.900159] usb20_host usb20_host: irq 43, io mem 0x00000000
<6>[ 1.900231] DWC_OTG: Init: Port Power? op_state=1
<6>[ 1.900257] DWC_OTG: Init: Power Port (0)
<6>[ 1.900347] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.900385] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.900423] usb usb2: Product: DWC OTG Controller
<6>[ 1.900449] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
<6>[ 1.900479] usb usb2: SerialNumber: usb20_host
<6>[ 1.901133] hub 2-0:1.0: USB hub found
<6>[ 1.901170] hub 2-0:1.0: 1 port detected
<6>[ 1.903449] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 1.903490] android_usb gadget: Number of LUNs=2
<6>[ 1.903519] lun0: LUN: removable file: (no medium)
<6>[ 1.903547] lun1: LUN: removable file: (no medium)
<6>[ 1.903985] android_usb gadget: android_usb ready
<6>[ 1.904374] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
<6>[ 1.904832] usbcore: registered new interface driver xpad
<6>[ 1.904931] usbcore: registered new interface driver usb_acecad
<6>[ 1.904962] acecad: v3.2:USB Acecad Flair tablet driver
<6>[ 1.905046] usbcore: registered new interface driver aiptek
<6>[ 1.905075] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
<6>[ 1.905113] aiptek: Bryan W. Headley/Chris Atenasio/Cedric Brun/Rene van Paassen
<6>[ 1.905204] usbcore: registered new interface driver gtco
<4>[ 1.905232] GTCO usb driver version: 2.00.0006
<6>[ 1.905312] usbcore: registered new interface driver hanwang
<6>[ 1.905394] usbcore: registered new interface driver kbtab
<6>[ 1.905423] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
<6>[ 1.905534] usbcore: registered new interface driver wacom
<6>[ 1.905563] wacom: v1.52:USB Wacom tablet driver
<4>[ 1.905587] ==gsl_ts_init==
<4>[ 1.905637] GSLX680 Enter gsl_ts_probe
<4>[ 1.905660] ==kzalloc success=
<4>[ 1.905679] [GSLX680] Enter gslX680_ts_init
<6>[ 1.906094] input: gslX680 as /devices/platform/rk30_i2c.2/i2c-2/2-0040/input/input1
<4>[ 1.906295] zhongchu_init_platform_hw gpio_request error
<4>[ 1.906842] I read reg 0xf0 is a
<4>[ 1.919410] I write reg 0xf0 0x12
<4>[ 1.939580] I read reg 0xf0 is 0x12
<4>[ 1.999750] I read reg 0xf0 is 12
<4>[ 2.019479] I write reg 0xf0 0x12
<4>[ 2.039659] I read reg 0xf0 is 0x12
<4>[ 2.209106] =============gsl_load_fw start==============
<4>[ 2.764815] =============gsl_load_fw end==============
<4>[ 2.909994] [GSLX680] End gsl_ts_probe
<4>[ 2.910121] ret=0
<4>[ 2.910582] sensor_register_slave:mxc6225,id=17
<6>[ 2.918771] using rtc device, rtc_hym8563, for alarms
<6>[ 2.918857] rtc_hym8563 2-0051: rtc core: registered rtc_hym8563 as rtc0
<6>[ 2.918976] i2c /dev entries driver
<6>[ 2.919993] lirc_dev: IR Remote Control driver registered, major 250
<6>[ 2.920046] IR NEC protocol handler initialized
<6>[ 2.920082] IR RC5(x) protocol handler initialized
<6>[ 2.920118] IR RC6 protocol handler initialized
<6>[ 2.920153] IR JVC protocol handler initialized
<6>[ 2.920187] IR Sony protocol handler initialized
<6>[ 2.920222] IR RC5 (streamzap) protocol handler initialized
<6>[ 2.920263] IR LIRC bridge handler initialized
<6>[ 2.920297] Linux video capture interface: v2.00
<4>[ 2.920935] def_ref_volt: 3300mV, curr_ref_volt: 2968mV
<4>[ 2.920980] start_charge_logo_display
<6>[ 2.922097] device-mapper: uevent: version 1.0.3
<6>[ 2.922811] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>[ 2.923180] Bluetooth: HCI UART driver ver 2.2
<6>[ 2.923223] Bluetooth: HCI H4 protocol initialized
<6>[ 2.923262] Bluetooth: HCILL protocol initialized
<6>[ 2.923386] cpuidle: using governor ladder
<6>[ 2.923421] cpuidle: using governor menu
<6>[ 2.923682] <iomux_gpio_to_mode> gpio(10864), is invalid
<6>[ 2.969386]
<6>[ 2.969392] drivers/mmc/core/core.c...2015.. ===== mmc_rescan Begin....[mmc0]
<6>[ 2.974513] rk29_sdmmc_change_clk_div..1706.. newDiv=80, newCLK=300Khz [sd_mmc]
<6>[ 2.974616] .Line3987..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sd_mmc]
<6>[ 2.974965] .Line3987..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sdio]
<6>[ 2.978028] usbcore: registered new interface driver usbhid
<6>[ 2.978061] usbhid: USB HID core driver
<6>[ 2.978608] logger: created 256K log 'log_main'
<6>[ 2.978756] logger: created 256K log 'log_events'
<6>[ 2.978895] logger: created 256K log 'log_radio'
<6>[ 2.979121] logger: created 256K log 'log_system'
<4>[ 2.979958] rk3026_get_parameter : Can not get ap_has_alsa from kernel command line!
<4>[ 3.000867] rk3026_probe : rk3026 delay_time is NULL!
<4>[ 3.021177] rk3026_probe : i2s sdi from acodec val=0x1420,soc_con[0] bit 10 =1 is correct
<3>[ 3.021275] rk3026-codec rk3026-codec: Failed to add route Mic Jack->Mic Bias
<6>[ 3.022495] asoc: rk3026-hifi <-> rk29_i2s.0 mapping ok
<6>[ 3.023550] asoc: rk3026-voice <-> rk29_i2s.0 mapping ok
<6>[ 3.024405] ALSA device list:
<6>[ 3.024428] #0: RK_RK3026
<6>[ 3.024615] GACT probability NOT on
<6>[ 3.024645] Mirror/redirect action on
<6>[ 3.024670] u32 classifier
<6>[ 3.024687] Actions configured
<6>[ 3.024709] Netfilter messages via NETLINK v0.30.
<6>[ 3.024801] nf_conntrack version 0.5.0 (6381 buckets, 25524 max)
<6>[ 3.025360] ctnetlink v0.93: registering with nfnetlink.
<6>[ 3.025439] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 3.025474] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 3.026007] xt_time: kernel timezone is -0000
<6>[ 3.026259] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 3.026527] arp_tables: (C) 2002 David S. Miller
<6>[ 3.026627] TCP cubic registered
<6>[ 3.026647] Initializing XFRM netlink socket
<6>[ 3.027544] NET: Registered protocol family 10
<6>[ 3.028860] Mobile IPv6
<6>[ 3.028933] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 3.029244]
<6>[ 3.029253] mmc_attach_sd..1230.. ===== Begin to identify card as SD-card. [mmc0]
<6>[ 3.029275] IPv6 over IPv4 tunneling driver
<6>[ 3.030609] NET: Registered protocol family 17
<6>[ 3.030687] NET: Registered protocol family 15
<6>[ 3.031038] Bluetooth: RFCOMM TTY layer initialized
<6>[ 3.031080] Bluetooth: RFCOMM socket layer initialized
<6>[ 3.031108] Bluetooth: RFCOMM ver 1.11
<6>[ 3.031131] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 3.031162] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 3.031370] NET: Registered protocol family 35
<6>[ 3.031709] [BT_RFKILL]: Enter rfkill_rk_init
<6>[ 3.031853] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 3.031902] [BT_RFKILL]: ** disable irq
<6>[ 3.032082] [BT_RFKILL]: bt shut off power
<6>[ 3.032107] [BT_RFKILL]: bt_default device registered.
<4>[ 3.032206] pmic set pm_suspend_volt:
<6>[ 3.032527] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<5>[ 3.032602] Registering SWP/SWPB emulation handler
<6>[ 3.033195] ddrfreq: verion 3.2 20130917
<6>[ 3.033227] ddrfreq: fix cpu pause bug
<6>[ 3.033268] ddrfreq: normal 396MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
<6>[ 3.034053] i2c i2c-1: sensor_probe: gs_mxc6225,0xda208000
<4>[ 3.034091] sensor_chip_init:gs_mxc6225:devid=0x0,ops=0xc0aef328
<3>[ 3.034251] rk_cam_cif(3274):rk-camera-rk3026 version: v0.3.18 Zoom by armret: 0
<6>[ 3.039450] input: gsensor as /devices/platform/rk30_i2c.1/i2c-1/1-0015/input/input2
<4>[ 3.039686] sensor_irq_init:use polling,delay=30 ms
<4>[ 3.039877] sensor_misc_device_register:miscdevice: mma8452_daemon
<4>[ 3.039913] sensor_probe:initialized ok,sensor name:mxc6225,type:1,id=17
<4>[ 3.039929]
<6>[ 3.040014] sensor_init: Probe name sensors
<4>[ 3.040062] sensor-dev.c v1.3 add sensor debug support 2013-3-15
<6>[ 3.041156] rtc_hym8563 2-0051: setting system clock to 2015-06-04 17:07:10 UTC (1433437630)
<3>[ 3.041207] i2c_check_rk610_ex: adap(0) is not exist
<6>[ 3.041642] Freeing init memory: 564K
<4>[ 3.048807] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<4>[ 3.069345] ret: 0
<6>[ 3.094014] rk29_sdmmc_change_clk_div..1706.. newDiv=0, newCLK=48000Khz [sd_mmc]
<6>[ 3.094214] mmc0: new high speed SDHC card at address aaaa
<6>[ 3.099762] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
<6>[ 3.106215]
<6>[ 3.106226] msdos_partition..466... ==== Begin to parse sdcard-partition. [mmc0]
<6>[ 3.106288] msdos_partition..535... ==== The sdcard has MBR. [mmc0]
<6>[ 3.106333] msdos_partition..548... ==== partition-1, size=7760896KB [mmc0]
<6>[ 3.106372] msdos_partition..576... ==== main partition-1....[mmc0]
<6>[ 3.106407] mmcblk0: p1
<6>[ 3.107059] sdmmc_rescan_try_freq..1909.. ===== Initialize SD-card successfully. [mmc0]
<6>[ 3.107116]
<6>[ 3.107122] drivers/mmc/core/core.c...2015.. ===== mmc_rescan Begin....[mmc1]
<4>[ 3.109700] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<6>[ 3.110872] keychord: using input dev rk29-keypad for fevent
<6>[ 3.119147] rk29_sdmmc_change_clk_div..1706.. newDiv=80, newCLK=300Khz [sdio]
<6>[ 3.122789] ddrfreq: change freq to 396 MHz when normal
<3>[ 3.159906] rk_cam_cif(1618):WARNING drivers/media/video/rk30_camera_oneframe.c_rk_camera_mclk_ctrl_1618: camera sensor mclk maybe not close, please check!!!
<4>[ 3.159974] ret: 0
<4>[ 3.189153] Probe gc0329_front_3 success
<4>[ 3.189411] ret: 0
<4>[ 3.219168] ret: 0
<4>[ 3.233150] gp_rknand_info = : 0xd90e9100
<4>[ 3.233297] rk30_chip_set:2
<4>[ 3.233420] FtlInit!
<4>[ 3.233489] No.1 FLASH ID:2c 44 44 4b a9 0
<4>[ 3.234562] FTL version: 5.0.9 20131224
<4>[ 3.259622] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<3>[ 3.279556] i2c i2c-1: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 2...
<3>[ 3.280033] i2c i2c-1: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 1...
<3>[ 3.280506] i2c i2c-1: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 0...
<3>[ 3.280552] gc0308_front_4(rk_cam_sensor:324): read reg(0x0 val:0x0) failed, try to read again!
<3>[ 3.280602] gc0308_front_4(rk_cam_sensor:683): read chip id failed
<3>[ 3.280811] rk_cam_cif(1618):WARNING drivers/media/video/rk30_camera_oneframe.c_rk_camera_mclk_ctrl_1618: camera sensor mclk maybe not close, please check!!!
<4>[ 3.280880] ret: 0
<3>[ 3.309273] camera 33-1-gc0308_front_4: Probe gc0308_front_4 failed
<4>[ 3.420147] gBootMedia = 1 gSdmmcFwPartOffset =0!
<4>[ 3.420177] rknand_buffer.c version: 4.40 20130830!
<5>[ 3.420534] 10 cmdlinepart partitions found on MTD device rk29xxnand
<5>[ 3.420569] Creating 10 MTD partitions on "rk29xxnand":
<5>[ 3.420603] 0x000000400000-0x000000800000 : "misc"
<5>[ 3.422536] 0x000000800000-0x000001400000 : "kernel"
<5>[ 3.424317] 0x000001400000-0x000002400000 : "boot"
<5>[ 3.426070] 0x000002400000-0x000004400000 : "recovery"
<5>[ 3.427896] 0x000004400000-0x000008400000 : "backup"
<5>[ 3.429803] 0x000008400000-0x000010400000 : "cache"
<5>[ 3.431848] 0x000010400000-0x000090400000 : "userdata"
<5>[ 3.437110] 0x000090400000-0x000090800000 : "kpanic"
<6>[ 3.439379] apanic: Bound to mtd partition 'kpanic'
<6>[ 3.439409] apanic: No panic data available
<5>[ 3.439448] 0x000090800000-0x0000b0800000 : "system"
<5>[ 3.441809] 0x0000b0800000-0x0000ea000000 : "user"
<6>[ 3.494194] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: discard
<6>[ 3.592003] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: discard
<6>[ 3.660258] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: discard
<4>[ 3.684693] UMP: Using OS memory backend, allocation limit: 268435456
<4>[ 3.684755] UMP: UMP device driver loaded
<4>[ 3.725295] Mali: Mali400 inside of rk3026!
<4>[ 3.725341] Mali: mali freq table num : 3
<4>[ 3.725377] Mali: mali freq table :Mali: 192,Mali: 256,Mali: 384,Mali:
<4>[ 3.725470] Mali: init mali clock success
<4>[ 3.728995] Mali: @@@@@@@Mali device driver loaded success@@@@@@@@
<4>[ 3.734617] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
<4>[ 3.736328] IPP init, version rk30-ipp 1.003
<3>[ 3.836556] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
<3>[ 4.211679] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
<4>[ 4.301668] vpu: power on
<6>[ 4.301794] VPU_SERVICE: checking hw id 8270
<4>[ 4.303311] vpu: power off...done
<6>[ 4.303390] VPU_SERVICE: init success
<6>[ 4.309391] rk_serial rk_serial.0: serial_rk_startup: line:0
<6>[ 4.309474] rk_serial rk_serial.0: +serial_rk_set_termios line:0
<6>[ 4.309537] rk_serial rk_serial.0: uartclk:3225600
<6>[ 4.309569] rk_serial rk_serial.0: baud:9600
<6>[ 4.309594] rk_serial rk_serial.0: quot:21
<6>[ 4.310451] rk_serial rk_serial.0: serial_rk_startup: line:0
<6>[ 4.310514] rk_serial rk_serial.0: +serial_rk_set_termios line:0
<6>[ 4.310718] rk_serial rk_serial.0: uartclk:3225600
<6>[ 4.310744] rk_serial rk_serial.0: baud:9600
<6>[ 4.310768] rk_serial rk_serial.0: quot:21
<3>[ 4.312036] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
<3>[ 4.312087] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
<3>[ 4.312684] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
<6>[ 4.317583] warning: `daemonsu' uses 32-bit capabilities (legacy support in use)
<3>[ 4.380524] android_usb: already disabled
<6>[ 4.384846] adb_open
<4>[ 4.599219] Current WiFi chip is ESP8089+BK3515A Combo.
<4>[ 4.599541] Current WiFi chip is ESP8089.
<6>[ 4.779861] .204.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
<6>[ 4.779912] .235.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
<6>[ 4.807206] .204.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
<6>[ 4.990319] EXT4-fs (mtdblock8): re-mounted. Opts: barrier=1,data=ordered,discard
<4>[ 5.010764] ------------[ cut here ]------------
<4>[ 5.010823] WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x48/0x1ac()
<4>[ 5.010856] autorequest GPIO-171
<4>[ 5.010921] [<c049fac4>] (unwind_backtrace+0x0/0xe0) from [<c04cb884>] (warn_slowpath_common+0x4c/0x64)
<4>[ 5.010982] [<c04cb884>] (warn_slowpath_common+0x4c/0x64) from [<c04cb91c>] (warn_slowpath_fmt+0x2c/0x3c)
<4>[ 5.011035] [<c04cb91c>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0648914>] (gpio_ensure_requested+0x48/0x1ac)
<4>[ 5.011090] [<c0648914>] (gpio_ensure_requested+0x48/0x1ac) from [<c0648ca8>] (gpio_direction_output+0x80/0x23c)
<4>[ 5.011200] [<c0648ca8>] (gpio_direction_output+0x80/0x23c) from [<bf077328>] (sif_platform_target_poweron+0x28/0x6c [wlan])
<4>[ 5.011338] [<bf077328>] (sif_platform_target_poweron+0x28/0x6c [wlan]) from [<bf0a90f0>] (esp_spi_init+0xf0/0x324 [wlan])
<4>[ 5.011441] [<bf0a90f0>] (esp_spi_init+0xf0/0x324 [wlan]) from [<c0495634>] (do_one_initcall+0x90/0x160)
<4>[ 5.011501] [<c0495634>] (do_one_initcall+0x90/0x160) from [<c04fd5cc>] (sys_init_module+0x1728/0x18dc)
<4>[ 5.011567] [<c04fd5cc>] (sys_init_module+0x1728/0x18dc) from [<c049a840>] (ret_fast_syscall+0x0/0x30)
<4>[ 5.011610] ---[ end trace 9c12bfdeafa6614f ]---
<6>[ 5.193457] EXT4-fs (mtdblock8): re-mounted. Opts: noauto_da_alloc,barrier=0
<6>[ 5.216140] EXT4-fs (mtdblock6): re-mounted. Opts: noauto_da_alloc,barrier=0
<6>[ 5.231145] EXT4-fs (mtdblock5): re-mounted. Opts: noauto_da_alloc,barrier=0
<4>[ 5.352979] Loading Chuwi V88 HUB access mod
<4>[ 5.353015] Greetings from crewrktablets 😉
<4>[ 5.353043] HUBaccess mod addres check failed [00 90 a0 e1]
<4>[ 5.703332] rk fb use 3 buffers
<6>[ 5.712131] lcdc0 win1 open,atv layer:2
<6>[ 5.712170] lcdc0 win1 closed,atv layer:1
<6>[ 5.934796] rk30-lcdc rk30-lcdc.0: blank mode:0
<3>[ 6.323483] gc0329_front_3(rk_cam_sensor:1188): generic_sensor_ioctl cmd(0x3) is unknown !
<3>[ 6.323505]
<6>[ 6.453337] tun: Universal TUN/TAP device driver, 1.6
<6>[ 6.453368] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<6>[ 6.471586] TCP veno registered
<6>[ 6.561138] usbcore: registered new interface driver dm9601
<6>[ 6.755664] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 6.888142] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
<6>[ 6.888669] usbcore: registered new interface driver rtl8150
<3>[ 7.234844] sif_platform_irq_init enter
<6>[ 7.601015] usbcore: registered new interface driver snd-usb-audio
<6>[ 7.630640] USB Serial support registered for cp210x
<6>[ 7.630951] usbcore: registered new interface driver cp210x
<6>[ 7.630982] cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
<6>[ 7.655766] USB Serial support registered for pl2303
<6>[ 7.656071] usbcore: registered new interface driver pl2303
<6>[ 7.656101] pl2303: Prolific PL2303 USB to serial adaptor driver
<6>[ 7.679380] USB Serial support registered for FTDI USB Serial Device
<6>[ 7.679939] usbcore: registered new interface driver ftdi_sio
<6>[ 7.679973] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
<6>[ 7.743475] usbcore: registered new interface driver cdc_acm
<6>[ 7.743510] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<3>[ 8.480867] init: untracked pid 422 exited
<3>[ 8.861185] sif_platform_irq_init enter
<6>[ 8.882306] esp_sdio: initializing netlink
<4>[ 8.882669] ++++++++
<4>[ 8.882680]
<4>[ 8.882694] enter rtc_irq
<4>[ 8.882703]
<4>[ 8.882710]
<4>[ 8.896130] request rtc irq succeeded!!!!!!!ret = 6!!!!!
<4>[ 9.598374] RKNAND_GET_DRM_KEY
<4>[ 9.598412] return ret = 0
<4>[ 9.598885] Current WiFi chip is ESP8089.
<6>[ 9.661294] ADDRCONF(NETDEV_UP): wlan0: link is not ready
<6>[ 9.929150] DWC_OTG: dwc_otg_hcd_enable, disable host controller
<4>[ 10.843437] old_capacity = 11 , new_capacity =1, capacity = 11
<4>[ 10.843467]
<6>[ 32.712928] request_suspend_state: wakeup (3->0) at 32713866380 (2015-06-04 17:07:40.161759379 UTC)
<6>[ 33.301329] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 33.301365] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 33.301386] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 33.301407] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 33.301429] lowmemorykiller: oom_adj 4 => oom_score_adj 235
<6>[ 33.301449] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 33.301471] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<4>[ 33.600469] Current WiFi chip is ESP8089.
<4>[ 33.631570] Current WiFi chip is ESP8089.
<4>[ 33.632214] Current WiFi chip is ESP8089.
<6>[ 34.001384] ADDRCONF(NETDEV_UP): p2p0: link is not ready
<6>[ 34.198620] ADDRCONF(NETDEV_UP): wlan0: link is not ready
<6>[ 34.206158] acc_open
<6>[ 34.206196] acc_release
<6>[ 35.203707] .204.. MMC0 receive the message sd-Checking from VOLD.[sd_mmc]
<6>[ 35.208469] .204.. MMC0 receive the message sd-Mounted from VOLD.[sd_mmc]
<7>[ 35.313161] wlan0: direct probe to a4:b1:e9:98:20:d0 (try 1/3)
<7>[ 35.324161] wlan0: direct probe responded
<7>[ 35.359238] wlan0: authenticate with a4:b1:e9:98:20:d0 (try 1)
<7>[ 35.363646] wlan0: authenticated
<7>[ 35.384282] wlan0: associate with a4:b1:e9:98:20:d0 (try 1)
<7>[ 35.392006] wlan0: RX AssocResp from a4:b1:e9:98:20:d0 (capab=0x411 status=0 aid=3)
<7>[ 35.392054] wlan0: associated
<6>[ 35.392657] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
<6>[ 39.096750] qtaguid: ctrl_counterset(s 1 10035): insufficient priv from pid=480 tgid=427 uid=1000
<1>[ 46.939368] start tx ba session,addr:a4:b1:e9:98:20:d0,tid:0
<7>[ 50.049231] wlan0: no IPv6 routers present
<7>[ 56.763774] i2s dma info:periodsize(4096),limit(6),buffersize(24576),over(0)
<4>[ 56.763988] rk3026_playback_path_put : set playback_path 2, pre_path 0
<4>[ 56.764017] rk3026_playback_path_put : set hp ctl gpio LOW
<4>[ 56.764041] --14
<4>[ 56.799186] 14 request = 0
<4>[ 56.837682] 14 set_mode = 0
<4>[ 56.867586] 14 set_state = 0
<4>[ 56.867625] rk3026_codec_power_up : power up playback
<4>[ 56.867815] rk3026_digital_mute : set hp ctl gpio HIGH
<4>[ 56.867847] ++4
<4>[ 56.882064] ++4 ret = 0
<4>[ 60.177980] rk3026_playback_path_put : set playback_path 0, pre_path 2
<4>[ 60.178009] rk3026_playback_path_put : set hp ctl gpio LOW
<4>[ 60.178032] ++14
<4>[ 60.192264] +set gpio_14, ret = 0
<4>[ 60.192287] rk3026_codec_power_down : power down playback
<6>[ 66.149895] binder: 427:483 transaction failed 29189, size 100-4
<3>[ 74.308409] init: untracked pid 1503 exited
<3>[ 74.549773] init: untracked pid 1515 exited
<6>[ 75.069555] binder: 1484:1496 refcount change on invalid ref 24
<6>[ 75.196605] binder: 1484:1650 refcount change on invalid ref 24
<6>[ 75.196635] binder: 1484:1650 refcount change on invalid ref 24
<3>[ 75.196661] binder: transaction release 33930 bad handle 24
<7>[ 75.570578] i2s dma info:periodsize(4096),limit(6),buffersize(24576),over(0)
<4>[ 75.570852] rk3026_playback_path_put : set playback_path 2, pre_path 0
<4>[ 75.570901] rk3026_playback_path_put : set hp ctl gpio LOW
<4>[ 75.570933] ++14
<4>[ 75.589463] +set gpio_14, ret = 0
<4>[ 75.589491] rk3026_codec_power_up : power up playback
<4>[ 75.589888] rk3026_digital_mute : set hp ctl gpio HIGH
<4>[ 75.589915] ++4
<4>[ 75.603985] ++4 ret = 0
<4>[ 80.899606] rk3026_playback_path_put : set playback_path 0, pre_path 2
<4>[ 80.899684] rk3026_playback_path_put : set hp ctl gpio LOW
<4>[ 80.899726] ++14
<4>[ 80.921739] +set gpio_14, ret = 0
<4>[ 80.921800] rk3026_codec_power_down : power down playback
<7>[ 166.105190] i2s dma info:periodsize(4096),limit(6),buffersize(24576),over(0)
<4>[ 166.105426] rk3026_playback_path_put : set playback_path 2, pre_path 0
<4>[ 166.105471] rk3026_playback_path_put : set hp ctl gpio LOW
<4>[ 166.105512] ++14
<4>[ 166.118135] +set gpio_14, ret = 0
<4>[ 166.118176] rk3026_codec_power_up : power up playback
<4>[ 166.118517] rk3026_digital_mute : set hp ctl gpio HIGH
<4>[ 166.118583] ++4
<4>[ 166.130518] ++4 ret = 0
<6>[ 169.239927] qtaguid: ctrl_counterset(s 1 10053): insufficient priv from pid=480 tgid=427 uid=1000
<6>[ 170.120051] qtaguid: ctrl_counterset(s 0 10035): insufficient priv from pid=480 tgid=427 uid=1000
<4>[ 172.214283] rk3026_playback_path_put : set playback_path 0, pre_path 2
<4>[ 172.214335] rk3026_playback_path_put : set hp ctl gpio LOW
<4>[ 172.214377] ++14
<4>[ 172.228818] +set gpio_14, ret = 0
<4>[ 172.228862] rk3026_codec_power_down : power down playback
<3>[ 179.734763] init: untracked pid 1747 exited
<3>[ 179.962869] init: untracked pid 1750 exited
123
2015/06/04 - 20:03
Negative, nothing detected by your kernel. Should look like this:
<6>[  165.746327] usb 1-1: new low speed USB device number 3 using usb20_otg
<6>[  165.967809] usb 1-1: New USB device found, idVendor=0f30, idProduct=0112
<6>[  165.967880] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[  165.967950] usb 1-1: Product: Dual Analog Pad
<6>[  165.967996] usb 1-1: Manufacturer: Jess Tech
<6>[  165.980049] input: Jess Tech Dual Analog Pad as /devices/platform/usb20_otg/usb1/1-1/1-1:1.0/input/input5
<6>[  165.980428] generic-usb 0003:0F30:0112.0002: input: USB HID v1.10 Joystick [Jess Tech Dual Analog Pad] on usb-usb20_otg-1/input0
Not really an idea. Is the kernel #445 currently running the genuine one coming with the tab?
soloprova
Forum Posts: 13
124
2015/06/04 - 20:16
sorry, I did not understand the question, when I followed your guide you have written to change the kernel in the downloaded folder with what you have done, I have done what was written, and I put the right kernel, I do not understand where is the problem that you posted, sorry!
I have to reinstall something?
125
2015/06/04 - 20:53
Ok, when this is the genuine kernel then we checked now everything we can check. The issue is hardware driven.
soloprova
Forum Posts: 13
126
2015/06/04 - 20:56
then? what can I do?
I might have been wrong to install the kernel? if yes, how can I try to install it again?
127
2015/06/04 - 21:03
Life is too short to get angry with an 2 Euro tab. Leave it as it is.
soloprova
Forum Posts: 13
128
2015/06/04 - 21:12
no joy in my life, damn tablet!
soloprova
Forum Posts: 13
129
2015/06/05 - 14:34
Screenshot_2015-06-05-14-17-53.pngImage Enlarger
I will not insist, but I am a stubborn person (please google translation does not make me write bad things), I tried an app to control why does not work and gave me this result.
obviously I do not know what it means, if someone knows can explain?
maybe I really worry too much for a toy from 2 euro ...
effesse72
130
2015/06/19 - 20:59
Good evening to all of you, I bought this tablet to my daughter in Italy. I never knew that has been gifted from a subscription! Now I see it. I updated the firmware with Oma 1.2 kernel #445 and others, hoping that she can use bluetooth functions too by OTG. I never was able to do that way. Can someone help me trying to add something to this tablet in order to make the Usb Bluetooth function working properly? Thank you very much in advance for. Best Regards, Stefano.
Image Enlarger
Image Enlarger
131
2015/06/19 - 21:16
Negative. Any device needs a kernel driver.
effesse72
132
2015/06/19 - 22:25
Thank you for the fast reply Oma guru. So, aren't you able to add a driver to this kernel?
Nor the kernel doens't contain other bluetooth (generic) drivers that can be activated at startup?
133
2015/06/20 - 01:55
Unfortunately we do not have the kernel sources.
VacaLeiteira
134
2015/06/20 - 05:17
Hi Oma7144.
First of all thanks for your work. I've noticed that you have made a build for the "Nameless 2 Euro Promotion Tab" that i hopefully will receive soon. My question is: As you make your own build for this tablet, even without the kernel source, how can i make my own build? I need a minimal "build" for my tablet, if possible, and all what i want is a usable machine to install firefox.apk, openoffice.apk, file access and network access. Nothing more. I don't care (i want, indeed...) if i can't have google market, or google play, or somewhere else. If i eventually need of some other "apk" i will download them and put it in the tablet. Quickly speaking, how are the tools that i need to build a minimalistic build like yours, but... minimalistic?
In alternative, it is possible to remove, from your build, all google software, keeping the kernel, the stuff needed to run "APK's", the access to wireless, sound, etc, and make the same goal? I don't want disabled applications. I don't want they at all. How, if possible?
If you don't have time to answer me, but know some sites that teach how to do that, it's enough.
Thanks in advance.
135
2015/06/20 - 06:49
Well, you got an OS for free ... for free means, you have to live with the google stuff.
Here you will find stuff for compiling a firefox OS: http://www.matchstick.tv/developer/software/
76 Guest(s)
Devices in use: Desktop (71), Phone (5)
swan12
heftpflaster
