[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
licata55
91
2015/05/06 - 21:06
I was able to see the tablet pc to rkandroidtool but sees it as maskrom mode . What should I do?
cloxyloredhat
92
2015/05/07 - 17:31
Hi Oma, thank you for your great job.
I've a nokia E5-00 with JoikuSpot and I would like connect my "OMA - Nameless tablet (build v1.1)" to Adhoc connection.
Could you be kindly to post "wpa_supplicant" file to enable Adhoc WiFi on Android Nameless Tablet?
Thank you very much.
licata55
93
2015/05/15 - 19:42
where can I find update.img of said tablet for use with rkbatchtool ? thanks
skinnie
94
2015/05/20 - 01:09
Oma thanks for this great rom.
I am using version 1.1 with great sucess. I found it snappier than 1.2 (And I am using a class10 micro sd, maybe due to poor sd card reader from the tablet or something else).
I only have one issue, the toggles disappear, now I only have this one, any hit on how to solve this? I tried clear cache but nothing. Screenshot here.
It's only a pity we can't get usb bluetooth to work, nor 4.4 as in other Rk3026 tablets. As soon as I can I will donate to you.
95
2015/05/20 - 09:59
??? as this is JB there is not top menue.
skinnie, brunolopes446
skinnie
96
2015/05/20 - 11:45
I forgot to say I edited build.prop and change tabletui to false.
It used to be fine (like in a mobile phone), but now only that toggle appears.
In tablet ui it is normal.
97
2015/05/20 - 12:53
Ah, ok. Playing arround will cause such things 😉
A lot of parameters set in build.prop are not defined in the framework. Changing them may give some strange effects.
To correct just flash system.img.
cloxyloredhat
98
2015/05/20 - 14:23
Hi Oma,
Is it possible to connect to an WIFI AD HOC connection using the Nameless tablet (build v1.1)?
I read on internet that editing and compiling "wpa_supplicant" file is possible...
Thank you for all
99
2015/05/20 - 15:49
Yes, it's all about sources ... which we don't have. Sorry.
cloxyloredhat
100
2015/05/20 - 16:11
Thanxs Oma for your reply
superdragonpt
101
2015/05/24 - 23:28
Hi
but, there's sources for this SoC out there.
Its still feasible the creation of an Kernel for this device.
Its just an matter of time (!)
Cheers
102
2015/05/25 - 00:04
Thank you for joining this forum to tell us this great news!
So, let's start the journey. Pls let us know of what parts your specific nameless tab consists. All components and chip by chip.
skinnie
licata55
103
2015/05/27 - 10:52
I turn to Oma , you can get a file from your rom update.img use with rkbatchtool ? My tablet always idb download error . Thanks
104
2015/05/27 - 17:02
Not much tested, but should work: Oma RK3026 make update.img
new-image.jpgImage Enlarger
licata55
105
2015/05/28 - 19:31
Solved , thank Oma for program creation update.img . Thank you very much.
66 Guest(s)
Devices in use: Desktop (57), Phone (9)
swan12
heftpflaster
