[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
eucurto
76
2015/04/12 - 13:24
Hi everyone!
I also own this tablet and i have flashed the great OMA rom!! Thank him for that!
I just have one problem... I cant login in Youtube app. It says: "An error occoured". The app works but without my account. Any ideas??
Thank you.
donatod87
77
2015/04/16 - 15:22
Hello to all the guys, thanks for your work.
My friends and I are doing an article in Italian on this tablet in promotion.
We would like to offer our users a guide in Italian (or in English with the steps very clear) on changing the original ROM with the OMA.
you can get help?
Thank you
InsaneTP
78
2015/04/19 - 03:59
Hi:
Tanks for the great work
I wish to know how to connect the tablet to a Smart TV
Every time i try to transmit the screen i cant get connection
I have the 1.2 rom from this topics
Tanks in advance
donatod87
79
2015/04/19 - 12:55
No one can help me in request written just above?
thanks
peppeng
Forum Posts: 11
Thanks Received: 6
80
2015/04/19 - 19:31
you can get help?
Thank you
hi I'm italian and I use this rom, how can I help you? send a PM if you want.. ciao!
The following users say thank you to peppeng for this useful post:
donatod87
donatod87
81
2015/04/19 - 20:42
you can get help?
Thank you
Hello, Peppeng.
I'm looking for clear guidance (step by step) in order to install the ROM OMA and some advice to customize following the change of ROM.
Can you help me?
I thank you in advance
Ciao, Peppeng.
Io sto cercando una guida chiara (step by step) per poter installare la ROM OMA e qualche consiglio per personalizzare in seguito al cambio della ROM.
Puoi aiutarmi?
Ti ringrazio in anticipo
peppeng
Forum Posts: 11
Thanks Received: 6
82
2015/04/20 - 18:35
Hello, Peppeng.
Can you help me?
ti ho scritto un messaggio
I wrote a PM ;)
donatod87
donatod87
83
2015/04/20 - 18:53
Ciao, si ho letto grazie, ti ho mandato un messaggio privato. Fammi sapere
Grazie ancora
donatod87
84
2015/04/21 - 18:01
HELP: When I install (Improve mounting FIX) with CW I have this final message INSTALLATION ABORTED
Why? I followed the guide to the letter!
Please if anyone can help.
electrode
85
2015/04/24 - 19:11
Hi! I have a problem with this tab. I tried to install the custom rom but during the process my pc shutted down and so the process was aborted. Now my tab i stuck in a boot loop, and the pc doesn't see it when plugged on USB. What can i do?
Slateman
86
2015/04/28 - 12:30
Hello everybody, I aim to those who have installed the rom Oma using Win 8.1 because I don't really know what to do.
I tried to install the Rom using the guide that I found into the .zip file, but apparently the installation was not successful because the official guide strangely have missed a crucial step: make the root with "Root and Dump" that I haven't found in the downloaded .zip file. I'm trying now to restart the installation, and after the uninstallation and reinstallation of the driver I tried to root with "Root and Dump", but the prompt doesn't go on after "Please wait ...". I also noticed that I can't turn on the tablet anymore (probably for the drivers who were broken with the previously failed attempts), but the tablet is still recognized by the computer with the name "Rockusb device", and is also recognized by RKAndroidTool. Needless to say, before that I enabled the usb debug.
I hope someone can answer me because I don't know where to bang my head anymore.
oliverb
87
2015/04/30 - 14:16
Hello, "reboot system now" doesn't work, noemly, touch doesn't work, and I restarted by power, ok?
licata55
88
2015/05/01 - 23:21
Hi, I'm Italian . Using rkandroidtool 1:37 I accidentally popped rk3188loader 1.24. The tablet will not light , the PC does not detect it and even rkandroidtool recognizes . There is no way of being able to recover ?
licata55
89
2015/05/03 - 21:32
Can anyone help me ? Thanks
Qualcuno può aiutarmi. Grazie.
peppeng
Forum Posts: 11
Thanks Received: 6
90
2015/05/04 - 12:15
for italian guys who contacted me via PM, for those who don't speak english or have some doubt, I past a little guide in the spoiler
Controlla che versione kernel hai: Vai in Impostazioni e Informazioni sul tablet; quindi clicca sul link del tuo kernel per scaricarlo fra questi "yudongsheng #442 preempt 07. Nov. 2014 or yudongsheng #445 preempt 25. Nov 2015" e poi lo sostituisci con quello presente in Oma ESP build v1.2
adesso puoi procedere col flash seguendo la guida dettagliata presente in Oma ESP build v1.2 (è necessario inserire una microsd per questa rom)
infine, dopo il primo avvio, installa il fix:
update 10.03.2015: improve mounting (necessario per mantenere le app quando le installi sulla sdcard)per farlo devi salvarlo nella cartella principale della sdcard, riavviare con l'app RebootMenu selezionando reboot recovery, (usa i tasti del volume e di accensione, rispettivamente per spostarti su e giu, e per selezionare) poi selezioni install zip from sdcard, choose zip from external sdcard e selezioni il pacchetto zip, e confermi...
un consiglio, non strafare con gli smanettamenti, hai comunque un tablet con caratteristiche molto basse, se metti troppa roba ricomincia a dare problemi e dovrai riformattare
naturalmente segui anche:
hints:
…use Nova launcher and set animation/scroll to “faster than light” (IO L'HO DISINTALLATO E USO IL LAUNCHER ORIGINALE) and …enable Entropy Fixer with value 256
if you have other questions, ask here and wait for an answer of some expert
admin, Harlock89
75 Guest(s)
2 Guest(s)
Devices in use: Desktop (68), Phone (6), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
