[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
61
2015/03/17 - 19:43
So use this kernel.img and overwrite the one in rockdev/Images.
dudestone
62
2015/03/17 - 19:46
sorry but still not understend. where i get the kernel to orwrite the one that is on /image?
63
2015/03/17 - 19:52
Download build v1.2 from post #1. Unzip the pack. You will find a folder rockdev/Images. Download the kernel #442 and unzip the file. Then copy the kernel.img into the folder rockdev/Images. That's all.
dudestone
64
2015/03/17 - 19:55
ohhh sorry i dont see that part need to download. now i get it lol sorry..
d) click EraseIDB
i dont have that option on the program
65
2015/03/17 - 19:58
Correction: eraseIDB means Lower Format.
Sorry.
dudestone
66
2015/03/17 - 20:03
f) reboot system now (both answers are No)
they only ask me one time yes
its normal??
67
2015/03/17 - 21:14
Do not choose yes, you will break superuser rights.
calcat
calcat
68
2015/03/20 - 21:54
Hello Oma, and thank you for your work.
I would ask you: is it possible to use a bluetooth usb device on this tablet?
Many thanks
69
2015/03/20 - 22:16
Negative. No kernel support for such devices.
ReDaLeRt
70
2015/03/22 - 10:40
Hi.
Can I use this tablet with an usb OTG cable plus a 3G/4G pen modem?
Thank you in advance.
egnos
Italy
71
2015/03/23 - 11:33
mballes said
Hello. There seems to be a problem with VOLD.FSTAB .
Good solution. Thx!
Here is a fix, to be installed via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2494
kindly you can have in detail the steps to be done to install this patch?
Thanks for your great help !!!
peppeng
Forum Posts: 11
Thanks Received: 6
72
2015/03/23 - 12:59
egnos said
Good solution. Thx!
download it and save in the download folder of the sdcard,
run Rebootmenu and select "reboot recovery"
you are now in the CWM.. use vol+ and vol- as up and down, and the power button to confirm the selection
select "install zip from sd card"
select "choose zip from external sdcard"
and then locate the zip file in Download
The following users say thank you to peppeng for this useful post:
egnos
skinnie
73
2015/03/25 - 23:23
Oma thanks for your work and rom.
One question, on the internet there are some RK3026 devices (some very identical to this tablet like this one http://www.banggood.com/ICOO-D70GN-RK3026-Dual-Core-1_0GHz-7-Inch-Android-4_4-Tablet-p-944158.html) with 4.4 like this one, any reason why this one doesn't have?
Kind Regards
duivelbryan
74
2015/03/27 - 03:39
is there anyway i can flash this with adb sideload ? i am very noobish at this stuff and my tablet wont boot anymore it only goes right to recovery v4.2.41 and i can't seem to find the stock version anywhere on the internet because nameless no brand
mballes
Forum Posts: 22
Thanks Received: 5
75
2015/04/10 - 10:36
Hello Oma . Are there any possibility of getting drivers for usb bluetooth ?. Thank You
83 Guest(s)
Devices in use: Desktop (66), Phone (17)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
