[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
peppeng
Forum Posts: 11
Thanks Received: 6
46
2015/03/10 - 22:48
I used the fix and now the sdcard works!
Thanks mballes and thanks oma!
BillyCohen
47
2015/03/11 - 00:27
peppeng said
BillyCohen said
Hello. I have a serous problem. I have downloaded your firmware 1.2, I have istall this, but now the wouch doesn't work good. It is work only for left side in vertical position, and when i click in left side the touch takes a comand like a press the right side.
Why?
Billy
did you control the kernel, did you use the right one?
Thank you. I have wrong the kernel.
Now all ok!
d_borghi
48
2015/03/11 - 08:04
I solved. Apps must be in internal memory. Then they don't disappear.
davidotablet
49
2015/03/11 - 21:23
Hi Oma,
I'm new to flashing devices(at least tablets/smarphones) and i still have some problems and questions.
I tried via ADB in recovery, but after upload kernel.img the update is aborted. Also fastboot does not recognize device in recovery mode, ADB does.
Then i also tried 2 different rk flashtools, the 1.7 and an other one, but keeping having problems there, it sais there is a device found, but when i try to choose kerel.img, it sais loading image failed(or something like that).
It 'should be' probems with drivers, tried reinstalling and installing 10 times, also on forum they speak about 2 drivers for fastboot, but in recovery mode device is recognized(only by adb).
So my questions are:
1)What flashtool/program do you use, and do you maby have tutorial of it?
2) What do you mean with "change it in folder rockdev/Image before flash." in OP? for 445 build(wich one i need).
3) What's the difference between the Kernel.img and these files, are they needed for flashing? :
Oma ESP build v1.0
update 15.02.2015: fix broken gms core
Oma ESP build v1.1
update 16.02.2015: swapp mounts
Oma ESP build v1.2  external sdcard mandatory!
Kind Regards, and good work!
50
2015/03/11 - 21:29
Just download the pack, tools and instructions are included.
davidotablet
51
2015/03/11 - 21:31
Ok found what you meant. Changed the image in the directory for correct built.
But now next problem : I tried "run" a few time in the flashtool(after i cleared).
One time it was almost finshed , but now it keeps hanging at : "Prepare IDB Fail."
What can i do to fix it and complete the installation?
Thanks.
Edit : Manged to get it working using a shorter/thicker usb cable...
And now at this step :
"go to app drawer, open RebootMenue and Reboot to Bootloader"
What is App drawer? Don't understand it.
Steps after that with CWM and android tool i get....Bet step a) i don't get...
ok found it, and off to bed now, thanks for the stuff!!
ok last question. With Xposed Framework > Starter Pack What can i do exactly with that and those .AKP packages? I found it was some kind of virtual environment to install apps...
fabri790
52
2015/03/12 - 23:40
Hi everyone, I've tried your rom 1.2 with kernel 445 (by the italian altroconsumo).
I followed the instructions of "Oma ESP v1.2 build external sdcard mandatory!", step by step, and when I get to the point 3-d, I get this error:
[img=http://s9.postimg.org/9kwniaba3/error.jpg]
Also what is meant by "external sdcard mandatory!"?
Should I put a sd card into the slot?
Thanks for the support
53
2015/03/13 - 06:19
Yes, one will not have the full functionalty without an external sdcard.
Fail could be a problem of a not proper connection. Use an other usb-cable.
dudestone
54
2015/03/17 - 18:42
hi, how i change the image to yudongsheng #442 preempt 07. Nov. 2014 ? i dont understend that step
55
2015/03/17 - 18:46
Unzip the file and copy the kernel.img into the folder rockdev/Images.
dudestone
56
2015/03/17 - 19:17
but the file is already in that paste.. i dont understend wich file for each produt i have to put
57
2015/03/17 - 19:22
See post #1. You should use the kernel which was on the tab.
dudestone
58
2015/03/17 - 19:27
yes i know but on first post dont say how\where he is .. i just dont understend that
59
2015/03/17 - 19:36
Goto settings/About tablet.
dudestone
60
2015/03/17 - 19:37
3.0.36+
yudongsheng@ubunt #442
69 Guest(s)
Devices in use: Desktop (61), Phone (8)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
