[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
31
2015/03/01 - 20:50
Negative, for KK one need a selinux kernel.
The tab hasn't build in all these chips ...
Seline
32
2015/03/01 - 22:21
Thank yoou for the response.
So is not possible to build a kernel with SELinux?
Another tablets with RK3026 chip has SELinux kernel. I don't know how to do it but don't understand why it is impossible.
33
2015/03/01 - 22:34
Nothing is impossible. If the supplier of the tab does publish GPL sources then one can compile a kernel.
bseixas
Forum Posts: 23
34
2015/03/02 - 15:41
I get a "login error" with google account in Youtube app with build v1.1, Playstore is working fine.
d_borghi
35
2015/03/08 - 21:27
Thank you Oma,
it's è very powerfull rom for an economic tablet.
Only one question:i've just installed 2 games from the google store.
both games are installed to sd card (32 gb).
when i reboot tablet, these 2 games disapperar. I must reinstall them afetr every reboot.
How can i solve this problem?
tnx
db
peppeng
Forum Posts: 11
Thanks Received: 6
36
2015/03/10 - 01:00
Hi everyone, I've tried your rom 1.2 with kernel 445 (by the italian altroconsumo) and works really good.. Much better than the stock rom that had many lags.
Thanks oma!
Ps: me too.. I installed a game in the sd card and when I restart the tablet there was not the game anymore :/
37
2015/03/10 - 05:38
Is this only with games or with other apps too? Can you pls check the sdcard for errors (on PC) or better format it before use with the tab.
mballes
Forum Posts: 22
Thanks Received: 5
38
2015/03/10 - 12:31
Hello. There seems to be a problem with VOLD.FSTAB .
I have solved with these parameters:
dev_mount flash /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
dev_mount sdcard /mnt/external_sd auto /devices/virtual/mtd/mtd9/mtdblock9
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb /devices/platform/usb20_otg/usb
Now if it works the external card and the applications and games will not disappear.
The following users say thank you to mballes for this useful post:
Oma7144, peppeng
peppeng
Forum Posts: 11
Thanks Received: 6
39
2015/03/10 - 12:45
I formatted the sdcard with fat32 fs, and then I tried to put facebook and tetris in the sdcard, when I reboot the tablet manually with the fisical button, both disappeared
edit: thanks mballes, I will try it.. but I have to delete the others parameters that are already there, or I have only to add what you have written?
BillyCohen
40
2015/03/10 - 15:06
Hello. I have a serous problem. I have downloaded your firmware 1.2, I have istall this, but now the wouch doesn't work good. It is work only for left side in vertical position, and when i click in left side the touch takes a comand like a press the right side.
Why?
Billy
peppeng
Forum Posts: 11
Thanks Received: 6
41
2015/03/10 - 15:22
Why?
Billy
did you control the kernel, did you use the right one?
mballes
Forum Posts: 22
Thanks Received: 5
42
2015/03/10 - 15:55
peppeng said
like this, what else, delete it
## Vold 2.0 Generic fstab
## - San Mehat (san@android.com)
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
peppeng
a11i7a73
43
2015/03/10 - 16:44
Hello, I also received the tablet in Italy through Altroconsumo and I had big problems:
1) the tablet is so poor that writing using the keyboard is impossible because some letters are not played or are played other in their place (es: I click on the "A" and the tablet plays "S");
2) I can not often start the applications installed (the message is: "Application not installed");
3) the touch keys work in alternate way;
4) even in some cases the tablet seems almost "possessed" because it opens the menu or other applications, or simply even  without anyone physically touches the screen!!! This is a sign of absolute instability of the system.
It is not good even for my three year old son, because you can not use the touch and the applications or menu windows will open and overlap themselves to each other.
Any of you, gentlemen, have had these same problems and can tell me a solution?
44
2015/03/10 - 17:29
What is the running kernel?
45
2015/03/10 - 17:32
Good solution. Thx!
Here is a fix, to be installed via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2494
peppeng
78 Guest(s)
Devices in use: Desktop (72), Phone (6)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
