ptolemaeusPer aspera ad astra, we rock the Tablets !
2015/02/12
Indeed,a missing info on my end, i wrongly though i provided in the other topic.
Tricky multitask late night does that to the brain :p
Thank you once again for your effort.
--edit--
Oma in v1.2 NAND is acting as external sd so i have no flash memory.
Does anyone else have the same issue?
Flash the build again, incl. Lower Format.
Mounts are swapped. You have 2 GB internal storage and up to 32 GB from your external sdcard now shown as NAND FLASH. So plenty of space to install i.e. Gameloft games. The remaining space on the NAND should now shown as SD-Card.
You are welcome! Updated post #1 with the hint that an external sdcard is mandatory.
2015/02/27
Hi Oma7144.
Thanks for the time taken to improve this tablet. I'm trying to flash it with v1.2 but I've run into some trouble, in point "3 d) click EraseIDB", I just can't find this EraseIDB button anywhere in AndroidTool v2.1.
What am I doing wrong? The tablet is on, AndroidTool says it found one loader device, but I'm stuck
Thanks in advance.
EDIT: ok, something went wrong the first time, but now it worked fine. Nice work
Fine.
Correction added to post #1: eraseIDB means Lower Format.
2015/03/01
Would it be possible to create a custom rom with Android 4.4?
And to activate the BT and multiple sensors included in the RK3026 chip (see image below)?
http://i1077.photobucket.com/albums/w467/9ce439a1/photo_2015-02-28_10-42-14_zpsyvat6xhh.jpg
Thank you very much!
59 Guest(s)
Devices in use: Desktop (55), Phone (4)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
