2017/03/09
Downloaded and used build v1.2. The proces worked well, I followed the instructions included. Overall, I find the tab somewhat slower. Another thing, I installed FBReader, MoonReader+ and Angry Birds. Few hours later, Angry Birds was not installed. After a reboot, same with Moon Reader+. I changed the sdcard (16G, speed 4), with a 8G, speed 10 adn a 4G spped 10. Same thing, apps randomly disappear. Btw, I use Total commander to browse and install things.
All sdcards were checked in Windows, filed with data and checked the data (crc) and the test was ok. I reboot in recovery, cleared data, cache and reboot, the problem still there. Any Idea? I have a spare 1G and 2G old transflash, should I check with those?
Another question: I have the backup of the original (stock) system. To flash it, I should follow the steps in your instructions?
2017/10/09
Hello all,Â
I updated recently to the 1.2 version, but I am experiencing the following issues:
super fast battery drain (like 5 minutes usage)
Continuous resets during normal usage. I can barely use it for more than 5 minutes before it resets (actually it shuts off).
it is very anoying since everything else works quite good.
any advice on how to troubleshoot this second issue? I’m quite a n00b on android but I can learn 🙂
EDIT: I tried to hook it to an external battery and it worked without resets for one hour. So I assume that I have a dying battery here.. anyone managed to change the default battery and put a bigger one inside?
Currently Online: dangerosu74
67 Guest(s)
Devices in use: Desktop (62), Phone (6)
