I guess this is not a RK3026 anymore. Pls check with this tool: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
2017/01/20
I guess this is not a RK3026 anymore. Pls check with this tool: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck- Oma -
Thanks forma the answer. I tried with tour instructions included in the zip. Installed and it work very well; noce work! 😉 anyway i can't fine a recovery that work. Twrp give black screen and the other vive strange colorful effects. Did you know wich can i installato? Thank you again.
Hm, maybe Translator error ... do NOT use stuff from this thread.
This here might be for your tab: http://www.arctablet.com/blog/forum/rk3126-entwicklung-und-customroms-development-and-croms/nameless-2-euro-promotion-tab-android-4-4-4-rk3126-and-nmc1000/?lang=fr
Negative. KK needs another kernel, which includes selinux.
2017/01/20
Hm, maybe Translator error ... do NOT use stuff from this thread.This here might be for your tab: http://www.arctablet.com/blog/forum/rk3126-entwicklung-und-customroms-development-and-croms/nameless-2-euro-promotion-tab-android-4-4-4-rk3126-and-nmc1000/?lang=fr
Thank you. I have exactly that model. I'll follow that instructions, thanks again! 😉
2017/01/23
hi oma Im back
by now there are 22:20 in Portugal Ive been here reading since 13:00 lol and Im so dam confused oh boy, right now Im trying to instal the http://crewrktablets.arctablet.com/?wpfb_dl=2714 rom in My Portuguese device and im getting this error when I press the run tab of the android tool check chip fail any way to solve this? I have a ESP8089 wifi chip i did the lower format and it worked
frazas said
hello I have an rk3026 runing your 1.1 rom, and it works great but unfortunatly it is android 4.2.2 is there any way to upgrade it to 4.4?
You try to flash a firmware for RK3126 into a RK3026 tab. This will for sure cause the error: check chip fail 😉
2017/03/09
I recently got a tablet rk3026. His intended use was as a ebook reader for my nephew, no internet, no facebook, some wifi to access my server.
Problems:
1. after 3..5 minutes, from 100% battery, it shuts down. Checked the battery voltage, is ok, the tablet reported it bad (cpu-z, android battery info). The true capacity may not be 2500mAh but, anyway....
2. the screen ratio is wrong. A circle (the analog clock) is a ellipse. Both on portrait (more visible) and landscape mode.
I rooted with the tutorial on this blog http://galindaines.blogspot.co.ke/2015/02/tutorial-root-y-flasheo-tablet.html, was ok
Calibrated the battery with this app https://play.google.com/store/apps/details?id=com.nema.batterycalibration&hl=es
specs: model rk3026; Android 4.2.2; kernel 3.0.36+ yudongsheng@ubuntu#435 Fri Aug 22 13:49:45 CST 2014
compilation rk3026-eng 4.2.2 JDQ39 eng.yudongsheng.20140905.164945 NTP
On his back: model no:759 and states that the battery is Li-ion 3.7V 2500mAh
Cpu-z tell me that the screen is scaled at 800x480, 140dpi, 6.66inch
It have 1G storage and 512M RAM (on the board is a free place to solder another flash. What if...?)
So, my question is: Is there a rom that I can flash to fix the battery and screen issues?
If needed, I have the backup (dump) the original system images, and I may post fotos from the inside of it.
Let me have a dmesg log.
2017/03/09
Let me have a dmesg log.- Oma -
Is this one?
While the battery was able to power the tab 44sec from 100% to shutdown, I change it with a new huawei 2400mAh. Now, after I charge to full, the tab take almost 24 hours to shutdown (no wifi, medium light).
The screen is a 773PTG700V65001 device, listed to have 960x640 native resolution. The CpuZ say that the resolution is 800x480.
Is there a way to send installed apps to external_sd intsead to the sd? Because the sd is internal flash storage and external_sd is the sd card.
kernel yudongsheng #435 SMP PREEMPT Fri Aug 22 13:40:45 CST 2014
Current WiFi chip is ESP8089.
You can use build v1.2 as is. As for the battery it may run flat due the age of the tab.
sebavodaPer aspera ad astra, we rock the Tablets !
145 Guest(s)
Devices in use: Desktop (133), Phone (12)
spiik
nikitamaan
VMILCINOV
