Sounds like a driver issue. Which windows?
There a several hardware revisions, pls use the right kernel.
2016/06/06
Hi @Oma7144
first of all thank you very much for your hard work! I have the 1.3 version of your rom and it works like a charm, the tablet is really fast and everything works better!
I want to ask only a thing: it's possible to merge external_sd and sdcard partition (so the two internal partition) and create a unic partiton?
No, not possible.
2016/07/12
There is a version of this 2€ tablet in Belgium too, by Test-Achats / Test-Aankoop (bilingual country ^^ ) . I didn't find the wifi version but give a try anyway; no touch screen on V1.2, look further and found the V1.3. That one work wonderfully well, what a difference with the slow buggy original *_*
Big thanks to you Oma
The only think I can add is a short description in french for search engine 😉
Si vous savez vous débrouiller en anglais et que vous cherché une custom rom pour la tablette de Test-Achats vous trouverez votre bonheur page13
Hm, unknown kernel. Pls dump the firmware first and upload the dump.
2016/08/17
Hello, I tried the link: http://crewrktablets.arctablet.com/?wpfb_dl=2399
Unfortunately it is not available: Fehler beim Aufbau einer Datenbankverbindung
Our server was down. Sorry for that. Pls try again.
2016/08/25
Hello. First of all thank you Oma, great work!
The Rom works perfectly! The only problem I get is when traing to run CWM from RKAndroidTool. It prints me this result:
Test Device Start
Test Device Success
No found offset of CWM partition
Download image failed
I have bought it in Italy, and the kernel is the #445. I pasted it in the image folder in rockdev.
Has anyone else had my problem?(I read the first 5 pages of this thread, but 17 were too much) I'm sorry to be adding another question!
Parameter, misc and CWM remains ticked.
126 Guest(s)
Devices in use: Desktop (117), Phone (9)
spiik
nikitamaan
VMILCINOV
