[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
226
2015/09/17 - 16:44
Nobody will really notice what is on the tab. They will throw it into the bin 😉
VacaLeiteira
227
2015/09/20 - 05:23
Hi. I have 2 questions.
The first is: how to change mac address? it's because i need to do that for administrative network reasons. It is an issue linked to the specific ROM or an hardware issue? i've tried with the busybox, netcfg, apps, but nothing works.
The second is: does this version of CWM (OMA ROM) support ADB in recovery mode?
Thanks in advance.
228
2015/09/20 - 10:09
A MAC address is given to a network adapter when it is manufactured. No ADB in CWM.
Willy163
229
2015/09/30 - 08:36
Hallo everybody.
I've just received a new version of this tablet.
Android is KK 4.4.4 and processor is an ARMv7 quad-core 1.2GHz.
The ROM stock is not so bad, but I can't root it with the OMA's root&dump tool.
Here are a couple of screenshots.
Cheers,
Willy.
Screenshot_2015-09-30-08-21-58-1.pngImage EnlargerScreenshot_2015-09-30-08-20-14-1.pngImage Enlarger
230
2015/09/30 - 16:14
This is a RK3126 architecture. Go over to the specific forum.
Willy163
modovich
231
2015/10/08 - 16:35
Should this ROM work on my tablet? Its 2LOOK, which is a brand in my country that buys generic and sticks 2LOOK and changes the model name
Image Enlarger
modovich
233
2015/10/08 - 16:53
I will do that now, thanks for replying. Is Windows 10 64bit fine? If not I have a WinXP PC.
234
2015/10/08 - 16:58
There is no Rockchip support for Win10 yet. Pls use WinXP.
modovich
235
2015/10/08 - 17:29
Alright, installed the driver. Moved everything from 2nd folder to C:/ and I tried running the root and dump, after I click ROOT all it says is: daemon started successfully and it doesent do anything from that part.
USB debuginning is enabled, and once I connect my cable to my tab it says its enabled.
Is there some sort of download mode I need to access or the tab should be booted normally? I retried 3 times, rebooted tablet and laptop every time but nothing.
I first need to root, and then dump, yes?
(This is all on WINXP)
modovich
236
2015/10/08 - 20:21
I was not able to root but I was able to dump firmware, is this ok? Root said su and busybox could not be moved to phone. I am uploading firmware now
https://mega.nz/#!yJgCGLbD!ziEwQf7vgozFXOo4PcC9TwJj3PLaqFtkDgkej5NhI3Y
valr
238
2015/11/11 - 13:08
Dump is ok.
Tab has RTL8188 wifi. So, this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-roverpad-trc7-android-4-2-2-jelly-bean-custom-root-firmware-20140421/?lang=fr
Just change the kernel in folder rockdev/Image before flash: http://crewrktablets.arctablet.com/?wpfb_dl=2699
Hello Oma I put your rom and goes very well but I need to replace the original stock ROM, you can? Can you help me to do this? Thanks
mazzo
239
2015/11/24 - 15:35
 Hello, after i installed the rom, the camera don't work and give me "the gallery application has crashed abnormally" how i can fix it? sorry for my english but i'm italian and i don't speak it very well. thanks
barbanza
240
2016/01/23 - 05:22
Hi Oma7144,
Thanks a lot your work, I have try it today and work fine in Windows 10 (64 bit include).
Issue: drivers are "unsigned" for Windows 10.
Sollution: "disable driver signature enforcement" in Windows 10
http://answers.microsoft.com/en-us/insider/forum/insider_wintp-insider_devices/how-do-i-disable-driver-signature-enforcement-win/a53ec7ca-bdd3-4f39-a3af-3bd92336d248?auth=1
Run driver installer and dont install Windows 8.1 patch for USB (dont are required).
Continue with normal installation ...
This sollution is same for all unsigned drivers (tablets, phones, ...).
Note: sorry my bad english.
The following users say thank you to barbanza for this useful post:
77 Guest(s)
Devices in use: Desktop (69), Phone (8)
cutierogue
hans41
rickybk
