Do a clean install of build v1.3Â incl. LowerFormat.
There is an instructions.txt in the download pack. You only need to choose the right kernel and copy it over.
Hm, same with the v1.2 build?
Nando13Per aspera ad astra, we rock the Tablets !
Yeah, the sdcard should be fat32 formatted before using it on a device.
2015/07/22
Hi Oma!
Unlikely my internal memory is faulty, so I have to send back the tablet to have a new one.
Before doing this, obviously I have to put back the original ROM that I've backed up after rooting with yours "Oma RK3026 Root and Dump" tool.
Could you please write me a procedure to flash back my rom? I have the following original files:
boot.img
cmdline.txt
dmesg.txt
kernel.img
logcat.txt
recovery.img
system.img
Thank you in advance for your help.
Willy.
No Rockchip driver for Win10 available, yet. Best is to use Win7.
2015/09/09
Hi everybody,
I installed Oma's ROM (1.3), but couldn't get through step 4 (flashing the CWM Recovery), because when I "reboot to bootloader" as per instructions, nothing happens and the tablet is not recognized by the PC (I need to long-press the reset button to start again the device).
Any suggestions?
Thanks!
2015/07/22
Willy163 said
Hi Oma!Unlikely my internal memory is faulty, so I have to send back the tablet to have a new one.
boot.img
cmdline.txt
dmesg.txt
kernel.img
logcat.txt
recovery.img
system.imgThank you in advance for your help.
Willy.
Does anybody can help me?
Thank you,
Willy.
Sorry, missed that here. Just change the system.img and you should be fine.
Willy163Per aspera ad astra, we rock the Tablets !
Most likely a driver issue. Power off; press Power and Vol up until status changed to "Found One Loader Device".
2015/07/22
Sorry, missed that here. Just change the system.img and you should be fine.- Oma -
Thank you OMA.
Finally I did it by replacing the whole image content and updating the "commandline" row in the "parameters" file accordingly to the one read in the dumped original files.
Thank you,
Willy.
137 Guest(s)
Devices in use: Desktop (124), Phone (13)
spiik
nikitamaan
VMILCINOV
