[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
196
2015/08/09 - 09:27
eolo87 said
sorry oma, why in terminal i write SU and the shell doesn't change from user@android to root@android?
Wait for the Superuser App to confirm.
Cicico
197
2015/08/09 - 09:52
that bad luck, I flash the tablet on the day before you posted the version 1.3 Oma 🙁
peppeng
Forum Posts: 11
Thanks Received: 6
198
2015/08/09 - 10:46
Possible, but this doesn't make sense for a tab with 4 GB NAND. For example one cannot download Asphalt 8 (about 1 GB game data).
I asked it because I don't use heavy games and in my case the version 1.2 with sd card mandatory was slower than the 1.1 (probably for the quality of my sd card)
I will try the new 1.3 with a new sd card in future... thanks 😉
199
2015/08/09 - 10:53
Yeah, theoretically the NAND is faster. However, through the creapy RK NAND driver/layer it should make no difference. Attached some typical test results.
v1.2_05a.pngImage Enlarger
peppeng
Willy163
200
2015/08/10 - 06:43
Ok, here is build v1.3 based on latest stock and kernel #497, preempt 24 Apr 2015 😉
Hi OMA.
Thank you for the update!
I've downloaded this build and I've noticed that the file kernel.img is not identical to one you've posted a few days ago for #497.
Which one should I use?
Willy.
201
2015/08/10 - 17:51
The flash-pack does include kernel #497.
Willy163
Cicico
202
2015/08/11 - 12:25
Hello Omar, With this latest version 1.3 there is still need to install this fix "update 03/10/2015: improve mounting (install via CWM)"?
203
2015/08/11 - 17:43
No, it is already inlcuded.
Cicico
204
2015/08/14 - 13:21
Hello, I do not know if it happens to someone else, but the youtube app once downloaded opens, but always appears the circle of loading and I do not see the video, if I try to log in, gives me an error and tells retry the login.
muscarda
205
2015/08/14 - 19:05
Hi all,
I just installed the custom rom, i saw that there is a 1.3 version. I installed the 1.2 from the first page.
Is it possible to update to 1.3 following the same instructions or there is something different to do when updating? Sorry for the question, but it's my first experience with android...
Are there performance fixes in 1.3 vs. 1.2? I mean, it is really recommended to update?
Many thanks
EDIT: It seems that Youtube is not working... Is this something expected? Thanks
206
2015/08/15 - 19:52
Confirm that youtube acts strange on build v1.3 (so in stock). One can start a video in the app per browser link but not the app itself.
youtube-in-browser.pngImage Enlargeryoutube-in-app.pngImage Enlarger
207
2015/08/15 - 20:03
Ok, uninstall the Youtube app and flash this fix via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2625
After boot one will find a Youtube app. Open the app and let it update.
v1.3_youtube.pngImage Enlarger
Cicico, egnos
Cicico
208
2015/08/16 - 12:44
hi Oma, first of all thanks to the resolution of the problem of youtube, I wanted to ask if in your rom there was an app that directly imported apps installed directly on the sd as in INT2EXT + or an option where you can decide whether to move completely the 'app?!?!
209
2015/08/16 - 12:58
There is no need to move apps (app2sd) or part of apps (symlincing) anywhere. This could be likely corrupt your system.
With the v1.3 one got 2 GB internal storage (app space) and all data (obb files) will be stored on the external sdcard (which is mounted as internal sdcard).
Do not play around with this mechanism and especially do not remove the sdcard!
Cicico, egnos
Nando13
210
2015/08/17 - 00:13
Hi Oma. I installed 1.3 after installation of 1.2. I have two problems: first, when i go in settings i can't access to developer options, after few seconds settings crashes. Second, 1.3 doesn't recognise the "external" sd card. How can I fix these problems? Thank you for the help.
71 Guest(s)
Devices in use: Desktop (63), Phone (8)
jacksonrid
usdown
ibob64
kawi
vetBro
