eolo87 said
I have a usb OTG cable and I need to connect a pendrive and a webcam, but nothing goes
Kernel 497
It is reported here several times that OTG support does not work on a certain population of "the" tab. I guess this is hardware driven. One can imagine that an 2 Euro Tab is not a A or B quality lot ...
2015/07/21
Flegias13 said
I have done the process to install the ROM but i have done a mistake.
When i process with androidtool the tablet was turned off ....Run failed could indicate a corrupted NAND. Most likely you have corrupted the NAND when the tablet turned off while flashing.
And is there no solution for restore NAND?
Unfortunately not.
Flegias13Per aspera ad astra, we rock the Tablets !
No, you cannot write on a corrupted NAND in any way.
2015/07/31
Kernel 497It is reported here several times that OTG support does not work on a certain population of "the" tab. I guess this is hardware driven. One can imagine that an 2 Euro Tab is not a A or B quality lot ...
Ok thanks but with the original rom the usb otg goes, now can you help me about the hubenable.ko? I've the error message access denied when I try to activate it on terminal, it's impossible to connect anything? Usb keyboard or pen drive or other?
Replace the right kernel in folder rockdev/Image and then start with the process acc. to instructions.
OTG and USB-Hub works fine here on my tab with the ESP build. The kernel module should run anyway. It is loaded by an init.d script. Maybe something got wrong during flashing.
Anyway, I guess it is time to do a fresh build based on the dump with kernel #497. We will see.
Ok, here is build v1.3 based on latest stock and kernel #497, preempt 24 Apr 2015 😉
Build should also work with the other tabs and their specific kernel (change in folder rockdev/Image before flash): kernel yudongsheng #435 preempt 22 Aug 2014, yudongsheng #442 preempt 07 Nov 2014, yudongsheng #445 preempt 25 Nov 2014, frank #486 preempt 17 Apr 2015
Oma ESP build v1.3 external sdcard mandatory!
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel frank #497 preempt 24 Apr 2015
– internal storage 2,0 GB and swapped mounts
– device spoofed as Nexus 7
– multi-user
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
– Oma -
Willy163, egnos, barbas66, nrfPer aspera ad astra, we rock the Tablets !
Possible, but this doesn't make sense for a tab with 4 GB NAND. For example one cannot download Asphalt 8 (about 1 GB game data).
58 Guest(s)
Devices in use: Desktop (55), Phone (3)
jacksonrid
usdown
ibob64
kawi
vetBro
