mrsmyle said
I have a new Kernel:3.0.36+
root@frank-desktop #497
Fri Apr 24 11:58:28 CST 2015
See post #143.
2015/07/22
Hi OMA.
I'm proud to say "thank you" by all yours italian followers.
I've two questions.
1) I would like to share the dump of my original stock ROM (kernel #497) but I'm afraid to upload also my Google acount with the ROM. Is the account saved with the ROM? I think no, but I want to be sure.
2) The file kernel.img is 8.388.608 byte but the content is all 0x00: it's empty! Is it normal or did I a bad dump?
Thank you so much!
Willy.
There is no user data in the dumped partitions. If you'd like you can send me the link via PM.
Could be that the kernel partiton is empty. Then the kernel is in boot and/or recovery partition.
Here is the kernel #497: http://crewrktablets.arctablet.com/?wpfb_dl=2603
Stilll ESP8089 wifi, so build v1.2 should work.
Willy163Per aspera ad astra, we rock the Tablets !
2015/07/22
Here is the kernel #497: http://crewrktablets.arctablet.com/?wpfb_dl=2603Stilll ESP8089 wifi, so build v1.2 should work.
Thank you so much Oma!!!
Willy.
2015/07/21
Help me Oma!!!
I have done the process to install the ROM but i have done a mistake.
When i process with androidtool the tablet was turned off and not in recovery mode as it should be. And now it doesn't work: when i turn on appers the write Android but it doesn't go on.
I would restart the process for installing your ROM but now in recovery mode the Androidtool don't find the dispositive.
could entry in recovery mode and i still have the backup in the microsd, but when i try to charge by external storage the tablet find the folders but there is a file to install. I should zip all the backup???
Thanks for the help
Which Windows? Pls re-install the USB driver.
2015/07/21
Win 7. I have tried to reinstall usb drivers but the the pc already releave the tablet (when i connect it appears: "Adroid Adb Interface") but the program AndroidTool doesn't reveale the device. But that after i have done the "low format" because before the same program reveale the tablet!!!
No, the ADB driver is something different. The Flash-Diver is not running and/or you did not start the tab into flash modus.
Yes, with all cable plugged. Use an USB2.0 port.
AndroidTool should notice: "Found One Loader Device".
2015/07/31
hi, sorry for my English but I’m Italian, I’ve got a problem with usb, I have a usb OTG cable and I need to connect a pendrive and a webcam, but  nothing  goes, the message in the usb host controller app is s3c driver not found, I try with terminal to execute hubenable.ko but I receive a message, error access denied you not have permission,  I have root and all files in R/W but the error message still again.. can you help me?
Kernel 497
2015/07/21
I'm sorry Oma,
but i have tried every way to connect e recognize the tab! But i think that when with RKandroidtool i have done "lower format" and after "run" it have done successfully "lower format" but it have failed "run" at 82%. So I think that something has been erased.
I would restart the tab as it was initially, is it possible? In this way i could restart the process for installing the ROM.
There is a program or a way to restore to the factory mode?
I'm sorry for my bad English.
Please Help me!!!!! Thanks
P.S: i am not so expert, please explain all as it possibile!!!
When i process with androidtool the tablet was turned off ....
Run failed could indicate a corrupted NAND. Most likely you have corrupted the NAND when the tablet turned off while flashing.
Flegias13Per aspera ad astra, we rock the Tablets !
66 Guest(s)
Devices in use: Desktop (62), Phone (4)
jacksonrid
usdown
ibob64
kawi
vetBro
