[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
effesse72
136
2015/06/20 - 09:31
Unfortunately we do not have the kernel sources.
Good morning Oma, so, you can not add a driver taken from other working tablets with similar hardware and version of kernel?
Isn't possible to decompile the .IMG files and reconstruct the file tree of the sources for this tablet?
It there must be a way to add a driver in linux ware systems without recompiling the whole kernel!
See below, thank you very much again for all your replies.
Here's the relevant piece from the init.rc file
# Prepare for bluetooth
    chmod 665 /sys/class/rfkill/rfkill0/state
    chown bluetooth bluetooth /sys/class/rfkill/rfkill0/state
    write /sys/class/rfkill/rfkill0/state 0
service dbus /system/bin/dbus-daemon --system --nofork
    socket dbus stream 660 bluetooth bluetooth
    user bluetooth
    group bluetooth net_bt_admin
service bluetoothd /system/bin/bluetoothd -n
    socket bluetooth stream 660 bluetooth bluetooth
    socket dbus_bluetooth stream 660 bluetooth bluetooth
    # init.rc does not yet support applying capabilities, so run as root and
    # let bluetoothd drop uid to bluetooth with the right linux capabilities
    group bluetooth net_bt_admin misc
    disabled
service hfag /system/bin/sdptool add --channel=10 HFAG
    user bluetooth
    disabled
    oneshot
service hsag /system/bin/sdptool add --channel=11 HSAG
    user bluetooth
    disabled
    oneshot
service opush /system/bin/sdptool add --channel=12 OPUSH
    user bluetooth
    disabled
    oneshot
service pbap /system/bin/sdptool add --channel=19 PBAP
    user bluetooth
    disabled
    oneshot
service hciattach /system/bin/hciattach -n -s 115200 /dev/ttymxc4 texas 3000000 flow
    user bluetooth
    disabled
Here's what I get when I do a manual hciattach. (Note I removed the -n option in this case)
# hciattach -s 115200 /dev/ttymxc4 texas 3000000 flow
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Serial port is opened
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Port settings is gotten
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Port settings is set
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Initial baud rate is set
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Break is sent
Found a Texas Instruments' chip!
Firmware file : /system/lib/firmware/ti/TIInit_7.6.15.bts
Sending script to serial device
Loaded BTS script version 1
texas: changing baud rate to 3000000, flow control to 1
CCCCCCCCCCCCCCCCCCCCWRCSCCCCCWRCCWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRCCWRWRWRWRWRCCCCCWRWRWRWRWRWRWRWRWRCCCWRCCCCCCCCCCCCCCCWRCCWRCCCWRCCCCWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRWRCCCCCCWRCCWRCCWRCWRCCCCCCWRCCCC
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: u->init is loaded
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Actual baud rate is set
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Line discipline is set
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: Ioctl device is set
Added device hci0
Sending script to bluetooth socket
[ATH_INFO] (external/bluetooth/bluez/tools/hciattach.c) <init_uart>: u->post is loaded
Device setup complete
# hciconfig
hci0:   Type: BR/EDR  Bus: UART
        BD Address: 34:B1:F7:97:8E:CE  ACL MTU: 1021:4  SCO MTU: 180:4
        UP RUNNING
        RX bytes:352 acl:0 sco:0 events:10 errors:0
        TX bytes:45 acl:0 sco:0 commands:10 errors:0
VacaLeiteira
137
2015/06/20 - 09:51
But how to make my own build, as you make this "custom root firmware"? Thanks?
effesse72
138
2015/06/20 - 10:00
@VacaLeiteira
you need to use some tools:
  •  RK3xxx Firmware Tools
  •  Wendal Tools
and study them of course to how do not 'brick' the tablet, bye bye.
brunolopes446
139
2015/06/24 - 02:18
First, let me thank you for this excellent and snappier Rom.
Is it possible to overclock through any kind of custom firmware? Would be interesting...
140
2015/06/24 - 14:02
Frequent tables are in the kernel.
mbriacuni
141
2015/06/24 - 19:51
Hi!
I've a problem with the sd card: i've initially insert a 2gb microsd and it working correctly but now i bought a 32gb microsd and when i try to format appear this error, "Storage damaged - You may have to reformat it." but i've try on pc and my galaxy s4 and it work properly. How i can resolve it?
Thank you and sorry for my english (i'm italian).
EDIT: I've tryed to format microsd with the galaxy s4 and when i mount it on tablet apparently working, but the device became very slow and just remove the sd returns to normal.
Spinax
142
2015/06/25 - 15:48
@oma7144
Hi! I just got this tablet and I have received with kernel version: 3.0.36+ root @ frank-desktop # 486 Fri April 17 2015 11:46:52 CT And what I see is not compatible with any of these kernels that are currently published. I wonder if sucrase a ROM for this kernel, a greeting!
144
2015/06/25 - 18:44
mbriacuni said
Hi!
Which build are you running? Swapped mounts?
mbriacuni
145
2015/06/25 - 21:37
mbriacuni said
Hi!
ver 1.2 and i've flashed the fix with CWM
146
2015/06/25 - 21:41
Ok, Android is now confused because the data partition was on the external sdcard. Copy everything from the old card onto the new card or do a fresh install of the build.
Best is to format a new sdcard with tools like this: https://www.sdcard.org/downloads/formatter_4/
mbriacuni
147
2015/06/25 - 21:50
i've already tried the first two tips, now try to format with this tool
mbriacuni
148
2015/06/25 - 22:58
I tried to format with the recommended tool and the first time i put it on tablet empty and the second time with data of old card but it doesn't work both times.. If you can not resolve, i think to try the version 1.1 because i don't need a lot of space for apps...
effesse72
149
2015/06/25 - 23:53
@Oma
Thank you very much again for the possibility you gave to us of experimental with our devices. Yesterday I was able to add the rtk_btusb.ko module in /system/lib/modules and loaded it because it was already called (insmod) just in one .rc.
Now I noticed that there isn't some commands similar to those in other tablet as hcitool and rfkill. How can I do to add them into the file structure and try to turn on or off some external bluetooth key? Where can I pick up them? TIA again, Stefano.
150
2015/06/26 - 17:21
Doesn't work this way. For BT over usb one need to compile a btusb.ko and a uhid.ko which are linked to the specific kernel. Also rfkill has to be inactive in the kernel (which isn't the case for the stock kernel). Different bins and libs are necessary to compile. Adittionally the framework needs to be compiled to make al those things work. Again, without sources no chance.
92 Guest(s)
3 Guest(s)
Devices in use: Desktop (84), Phone (8)
swan12
heftpflaster
