[ ROM ] Nameless 2 Euro Promotion Tab Android 4.2.2 Jelly Bean custom root firmware (2015/02/13)
Thanks Received: 1385
2015/02/14 - 17:33
Gents,
this is a Jelly Bean build for the "Nameless 2 Euro Promotion Tab" currently sold in Spain and Portugal. Build is for ESP8089 wifi ;-)
Pls check the kernel (settings/About the tab), there are different hardware revisions in the field.
If the running kernel is yudongsheng #442 preempt 07. Nov. 2014 or yudongsheng #445 preempt 25. Nov 2014 or frank #486 preempt 17. Apr 2015 > change it in folder rockdev/Image before flash.
Oma ESP build v1.0
update 15.02.2015: fix broken gms core
Oma ESP build v1.1
update 16.02.2015: swapp mounts
Oma ESP build v1.2  external sdcard mandatory!
update 10.03.2015: improve mounting (install via CWM)
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel yudongsheng #435 preempt 22. Aug 2014
– internal storage 2,0 GB and swapped mounts
– device spoofed as Nexus 7
– multi-user
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
Correction: eraseIDB means Lower Format.
 – Oma -
V17HD_20c.pngImage Enlargerv1.0_01-2.pngImage Enlargerv1.0_02-1.pngImage Enlarger
v1.1_02-1.pngImage Enlarger
v1.1_05-1.pngImage Enlargerv1.2_03.pngImage Enlarger
Linares9, ptolemaeus, pll, bseixas, peppeng, egnos, albertsoft, Willy163
2015/02/14 - 17:42
Willy163
amendesplacido
2015/02/14 - 20:34
my touch doest not work with this rom =( i can boot but i get stuck on the lockscreen because i have no touch =( back to stock rom and the touch is ok again
2015/02/14 - 20:36
What is the kernel (see settings/About the tab) of your stock rom?
amendesplacido
2015/02/14 - 20:42
3.0.36+
yudongsheng@ubuntu #445
tue nov 25 20:09:45 CST 2014
2015/02/14 - 20:44
Ok, seems we have different hardware revisions in the field. Can you pls upload the kernel?
amendesplacido
2015/02/14 - 20:54
sure - http://goo.gl/WZlLAI
it would be really nice to see my touch work with this rom :)
2015/02/14 - 20:57
Thx. Kernel.img does not contain a kernel. Pls upload the boot.img.
amendesplacido
2015/02/14 - 21:07
2015/02/14 - 21:12
Here is kernel #445. Change in folder rockdev/Image before flash.
amendesplacido
2015/02/14 - 21:39
Thank you Oma!! Now I have a working custom rom and recovery =) really appreciate it =)
ptolemaeus
Forum Posts: 13
2015/02/15 - 02:14
Just finished testing, everything working, much better that the stock rom.
Thank you for your effort.
2015/02/15 - 06:49
Fine. Thank you guys for feedback!
2015/02/15 - 14:42
Mega-Samu states some issues with google services. I haven't noticed that. Anybody else?
Edit: got it ... the stock firmware comes without gms core.
Anything else to improve?
ptolemaeus
Forum Posts: 13
2015/02/15 - 16:05
Add google account - success
download and install from play store - success
I don't have much time today to further testing unfortunately but will keep posting as i can.
I will need to tweak Nova Launcher (g-sensor not working on desktop and app/widget page only).
93 Guest(s)
3 Guest(s)
Devices in use: Desktop (82), Phone (10), Tablet (1)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
