Gents,
this is a KitKat build for Intracon FX 2 Pad 7 Bluetooth. Build is for RTL8723 wifi
PCB is 86v. Screen 800x480. Revision E, Serial Number starting with 1410E....
– system ext4
– selinux kernel bx #17 preempt 8. Apr 2014
– unified internal storage
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
– Oma -
51 Guest(s)
Devices in use: Desktop (41), Phone (10)
hellander
elousstad
relaytester
revoltown
tdomnic024
