Gents,
this is a KitKat build for the 9" Dragontouch R93. Build is for RTL8188 wifi, however one need a selinux kernel.
– system ext4
– selinux kernel incar #103 preempt 14.07.2104
– 2 GB internal storage
– device spoofed as Nexus 7
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
- to improve UI feeling disable all animation scales in developer options
– to disable su notifications change notification in su app
– Oma -
102 Guest(s)
Devices in use: Desktop (86), Phone (16)
cutierogue
hans41
