2014/06/22
Well, tried to other build with my original kernel and same issue. Even the original TITAN logo appears to the upper left corner leaving a dark space of 4 cm on the right and 2 cm on the bottom.
I will try to revert to the original stuff with the CD that comes with the tablet.
wish me luck
Santi
No way. Sorry.
Which tab do you have?
The screenshot shows a working Wifi. What exactly is the problem?
2014/10/17
The screenshot shows a working Wifi. What exactly is the problem?- Oma -
it shows i know.. but when i open google store or chrome or anything that need connection i have ''retry to connect again..'' i check my wifi home and it works fine with all othes device exept the tablet..
The problem is the same in JB and KK?
Can you do a factory reset and check wifi again?
2014/12/07
Hello, can u told me please if i can flash this fw on my tablet? i have a Smart Tech TAB 908DC... i didn't find a support page on internet... i try to search kernel 3036+ malong@malong #97, i didn't find nothing... Specs image
[Image Can Not Be Found]
-as21ro-
No, you can not.
222 Guest(s)
Devices in use: Desktop (214), Phone (8)
