Gents,
This is my first custom firmware for a RK3026 tab
 Cube U25GT2-T by Oma KitKat build v1.0
 Cube U35GT2-T by Oma KitKat build v1.1
– system ext4
– selinux kernel ruan #88, ruan #336 [v1.1]
– internal storage 2,0 GB
– device spoofed as Nexus 7 [v1.1]
– ethernet support
– init.d support [v1.1]
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
hints:
- to improve UI feeling disable all animation scales in developer options
- to improve battery drain set keep wi-fi on during sleep to never
- to get full access to the build enable /system rw in File Manager HD
- to disable su notifications change notification in su app
- to prettify the build use Xposed Framework > Starter Pack
- to enable multi-user use the Xposed module Multi Users
This is a gen2 loader firmware.
– Oma -
d666anggel, svivaresPer aspera ad astra, we rock the Tablets !
Could you please make a build for my Odys Bravio device?
It has also a resolution of 1024x768, 1GB RAM, 8GB internal storage, Android 4.2.2, 3.0.36 Kernel..
Seems to be really near to this cube tablet.Â
I can provide some files to you if you need them.
Until now, we from rkdroid.info worked on a 4.2.2 rom. Works on some devices, but not at all.
Having KK on my tablet is a dream
Thank you and best regards
Marcus
Odys Bravio - 7.85" Tablet - 4.2.2 Stock - Rooted, xPosed
Odys Connect - 7" Phablet - 4.2.2 Stock - Rooted, xPosed
Pls open a new thread and upload a dump of the firmware and a dmesg log.
2014/04/25
menu where you need to look here:
1) go to "Language and Input" in the
2) Next, go to the "Voice Search"
3) You have a point there something like "Download offline speech recognition"?
What do you like to do?
Google excluded some devices to download offline files due to hardware limitations. I cannot find an approach for an workaround, yet. Sorry.
2014/04/25
On firmware Cube U25GT2-T by Oma KitKat build v1.0 I had already decided this problemmu. Writing files from http://rghost.ru/48352233.
thank you
2014/06/20
Oma7144, I used "Â Cube U25GT2-T by Oma KitKat build v1.0" to try update the firmware on a U25GT2-H.
Now when i press the power button, it shows me a white screen and then turns off again.
I have these details from trying to export the kernal:
FIRMWARE_VER:4.4.2
MACHINE_MODEL:V17HD by Oma
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3066
CHECK_MASK: 0x80
KERNEL_IMG: 0x60408000
#RECOVER_KEY: 1,1,0,20,0
I also have an identical device in working order.
Can you assist me in getting this device up and running again?
U25GT2-H has other hardware. Try this build. Kernel and loader for your tab is in post #2. Change it in the download pack before flash.
2014/06/20
Thanks Oma7144, you are the tablet master!
My tablet is up and running again. the only issue I have so far is the WiFi not turning on.
I have 2 more questions:
1. Is there no working kitkat build for the U25GT2-H?
2. How would I go about making a backup of the firmware from a working device? (With the intention of reloading it should something go wrong when flashing a tablet)
If you have a running build you can do a CWM backup.
Let me see your hardware. Download a Terminal Emulator from Play Store. Boot the tab fresh and type:
su
dmesg >/mnt/sdcard/dmesg.txt
Zip the logs and upload it here.
Ok, Atheros 9271 wifi.
Pls try this build: http://crewrktablets.arctablet.com/?wpfb_dl=1869
Just change your kernel in folder rockdev/Images.
138 Guest(s)
Devices in use: Desktop (130), Phone (8)
spiik
nikitamaan
VMILCINOV
